Vx220 Turns But Wont Fire
vx220 starter fuelpump fuelcutoffdevice
9 replies to this topic
#1 VX220 RABITA
VX220 RABITA
  • 5 posts
Posted 23 August 2012 - 08:47 PM
Hi All, Im having problems with my vx220. It hasnt been used in 4 months and would not start so i replaced the battery. It ran fine but but when reversing i breaked suddenly and the car completley cut out. I replaced the fuel pump checked the relays and hit the fuel cut of device but the car still wont start. Any suggestions would be much appreciated. :happy: Cormac
#2 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 23 August 2012 - 08:49 PM
I assume you have enough fuel? Have you checked the spark?
#3 VX220 RABITA
VX220 RABITA
  • 5 posts
Posted 23 August 2012 - 09:00 PM
Yeah tanks full, when you say spark do you mean spark plugs ? If so then yeah i checked them and there in pretty good nic
#4 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 23 August 2012 - 09:56 PM
Have you checked the battery hasn't moved and is still fixed in place by the backing plate? Check the terminals too in case its shorted on the tub.
#5 siztenboots
  • 26,613 posts
Posted 24 August 2012 - 07:44 AM
check fuel pump relay , when you turn on ignition can you hear fuel pump ( not the buzzing throttle ) , the relays are in the boot hidden right behind the NSR light
#6 FLD
FLD
    WANNABE MY LOVER
  • 13,717 posts
Posted 24 August 2012 - 10:33 AM
Any EML? Whereabouts are you? The reason I ask is that help may not be too far away.
#7 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 24 August 2012 - 12:58 PM
my car turned over without firing, that was becuse my engine imploded... As sugested post your location and someone might be able to come have a look. battery sounds likly as it was just replaced :)
#8 VX220 RABITA
VX220 RABITA
  • 5 posts
Posted 24 August 2012 - 06:48 PM
I can hear the relays clicking but cant hear any buxxing noise
#9 VX220 RABITA
VX220 RABITA
  • 5 posts
Posted 24 August 2012 - 06:49 PM
Im in meath, ireland
#10 VX220 RABITA
VX220 RABITA
  • 5 posts
Posted 24 August 2012 - 06:50 PM
Terminals are good and battery still in place in the backing place
Also tagged with one or more of these keywords: vx220, starter, fuelpump, fuelcutoffdevice
