M32 Gearbox Top Mount - Dg To Make A Batch
#61
Posted 25 February 2013 - 12:13 PM
#62
Posted 25 February 2013 - 10:28 PM
Clutch disc has to be different so and get LEH one. But LEH disc is bigger than Z20LET and locating is not the same from axle so I had to fit flywheel of Z20LEH too
Conclusions :
M32 + Z20LEH clutch + mecanism + flywheel
Edited by TATONSPEEDY, 25 February 2013 - 10:28 PM.
#63
Posted 03 March 2013 - 11:07 AM
Like it ?
#64
Posted 03 March 2013 - 02:22 PM
#65
Posted 03 March 2013 - 02:54 PM
Hi,
About the gear stick mechanism (with hand brake lever).
Is it one from an Europa or an other one.
And the CV heatshield. Is it a Europa one ?
Thanks
From Europa, Yes !
#66
Posted 03 March 2013 - 05:41 PM
#67
Posted 03 March 2013 - 06:25 PM
Thanks
Is it a D124F0002F with internal lift mechanism or a C124D0002F with external lift cable ? seems like the first one.
Yes for the ref
Written "coffle" on invoice so seems to be internal but was delivered with gear cable and hand brake cable.
#68
Posted 03 March 2013 - 07:52 PM
#69
Posted 03 March 2013 - 08:09 PM
#70
Posted 03 March 2013 - 10:20 PM
Thanks
Yes for the ref
I think it was about rear reverse selection and mine is internal the gear level. As far as i can see on Lotus drawing, there is another system for the rear selection which should be external.
#71
Posted 03 March 2013 - 10:22 PM
So the bracket you made for the box side is not needed if you have the good cables !
2 options :
1 - VX220 cable with adaptated ALU bracket to avoid to change it (but 1st gear is on the right hand ! I'm working to convert gear mecanism to change it)
2 Europa cable with Europa ALU bracket. perfect.
Edited by TATONSPEEDY, 03 March 2013 - 10:23 PM.
#72
