Uprated Heater Mk2 Installation
173 replies to this topic
#141 booshtukka
booshtukka
  • 255 posts
Posted 02 February 2015 - 05:20 PM
I figured that out. "Easy" still seems relative. :)
I seem to have a random leftover cable. I assume this commons up with the other black cable on the bracket?
#142 fezzasus
Posted 02 February 2015 - 05:33 PM
Oh, that should be connected to the thumb screw on the mount. oops.
#143 booshtukka
booshtukka
  • 255 posts
Posted 02 February 2015 - 05:56 PM
Does it matter what coolant i top up with? The old one was pink if that matters. Can I just grab anything from texaco and refill? The old stuff has bits in it.
#144 fezzasus
Posted 02 February 2015 - 06:08 PM
In short, yes.
Green/blue = inorganic corrosion inhibitor
orange/pink = organic
combine the two and you will silt up the system. Stick to one type and you'll be fine.
#145 booshtukka
booshtukka
  • 255 posts
Posted 02 February 2015 - 07:10 PM
Okay, last bit. "[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]use hose clamp on heater end" - what hose clamp?[/color]
#146 booshtukka
booshtukka
  • 255 posts
Posted 02 February 2015 - 08:05 PM
Finished! Mostly… Seems to be working okay without the hose clamp. I mean - air came out of the vents! That's new.
Need more coolant, will pick that up tomorrow. I'm sure I poured in a lot more than came out, but apparently not.
A few things:
1) The spades seem very loose. I will re-use the old connector, I think.
2) The heat control is the wrong way round - my fault, but I assumed the pins would be at the bottom…
3) The fan control seems fastest on position 1, and slower on 2 and 3. Is something wired in wrong?
4) Should I be concerned that there's no hose clamp? I saw people had trouble attaching the tube to the heater, but I had the opposite issue - no problems attaching to the heater, nightmare attaching the other end…
Other than that, ten minutes in the driveway and hot air came out! AMAZING!
P.S. It's a bit sad when you're chuffed when your heater actually heats something…
#147 booshtukka
booshtukka
  • 255 posts
Posted 01 March 2015 - 09:22 PM
So, I've run it for quite a while and not getting hot air. It's not freezing cold but not warm either. Definitely getting air though. Is something not connected right?
#148 fezzasus
Posted 01 March 2015 - 09:30 PM
Does the dial change the temperature from hot to cold?
Have you checked the pipe connection from the heater to the cabin?
Does the air get hotter when stationary? I've seen some diverter flaps that are so damaged that they just let in air regardless of how much air is coming from the heater
#149 booshtukka
booshtukka
  • 255 posts
Posted 01 March 2015 - 10:16 PM
The dial doesn't seem to change anything. There is lots of air so I'm sure the pipe connection is good. The temperature is the same whether moving or stationary.
#150 fezzasus
Posted 01 March 2015 - 10:43 PM
hmm, could you put the dial in a middle position and touch the top of the silver valve, you should feel it clicking if it's working
#151 booshtukka
booshtukka
  • 255 posts
Posted 01 March 2015 - 10:44 PM
Sorry, which valve? Do you have a picture?
#152 badgerade
badgerade
  • 1,173 posts
Posted 02 March 2015 - 01:38 PM
It's on the heater unit.  Middle of the pic here, near the spade connectors on the yellow and green wires :
#153 Gopherit
Gopherit
  • 76 posts
Posted 11 March 2015 - 08:23 PM
Attached File  P1250885ccc.JPG   34.99KB   12 downloadsFitted the kit having got the old heater out in one piece and no blood spilt. Felt good about it until I switched on and the heater end of the air duct blew off - in spite of the hose clamp.
Sorted that but just as I was about to award myself a beer noticed that the silver diverter valve on the rad in/out pipes was the other way round to that in the guide picture. I fitted it all just as it came to me from Fez, but I am summing that I now need to swap the pipes over? See pic (?45kb max pic size - seems more than small?).
#154 karlb123
karlb123
  • 322 posts
  • Interests:Actual NPC engineer.
Posted 11 March 2015 - 10:19 PM
My heater valve is the other way around.
#155 furtive
furtive
  • 1,134 posts
Posted 27 April 2015 - 02:36 PM
My heater was blowing all cold the other day. This weekend it was blowing all hot. Would this point to the valve being knackered rather than the controller? I'll try the suggestion above to see if I can feel it clicking
#156 furtive
furtive
  • 1,134 posts
Posted 01 May 2015 - 02:44 PM
It's clicking when the heater dial is set to the mid-point, so I guess that means it's working?
#157 fezzasus
Posted 01 May 2015 - 04:14 PM
Yes.
How quickly is it clicking? Some of the early ones would click too fast which would overhead the valve and cause it to stop opening or closing.
#158 furtive
furtive
  • 1,134 posts
Posted 01 May 2015 - 04:24 PM
Roughly once per second I would say
#159 furtive
furtive
  • 1,134 posts
Posted 01 May 2015 - 05:13 PM
Hmm, just went out for a spin and tested it, and it seems to be working again now!
#160 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 14 May 2015 - 09:06 AM
Hi Tom,
Any sign of those controllers ? Summer is on the way, will need cold air :)
