Uprated Heater Mk2 Installation
173 replies to this topic
#161 booshtukka
booshtukka
  • 255 posts
Posted 06 July 2015 - 09:20 AM
Bump
Pretty certain my thermostat is doing (and has never done) anything… It blows vaguely warm air, regardless of the heat position.
#162 fezzasus
Posted 06 July 2015 - 10:02 AM
Bump
Do you have a multi meter?
If so, disconnect the plug going to the silver valve (bit on the right hand side of this photo with the two hoses connected)
And plug the multi meter into it, with the dial set to half way 9and ignition on) you should be seeing it change from 12v to 0 v every 1-2 seconds.
If it is doing this, it's a new valve time, if it's fixed at a specific voltage, it's new controller time.
#163 booshtukka
booshtukka
  • 255 posts
Posted 07 July 2015 - 09:04 AM
So, this is weird. After how ever many months of telling myself "I should really get around to figuring out what the problem is", I remember today to throw a multimeter in the passenger seat. I was thinking that at lunchtime I'd test it, and respond after.
On my thrilling morning drive around the M25, the car was suddenly really hot. I have the controls set to full heat, full fan, and just leave them like that all the time. But the vent was kicking out some serious heat - which has never happened before. I set it to cold, the air went cold, I set it to hot, it got hot again. I did this all the way to work, revelling in the joy of it working.
So, mad right? On the day I bring the multimeter, it miraculously fixes itself. Have you wired in a screw-with-people module that you can remotely trigger? Is there something I should still check?
#164 fezzasus
Posted 07 July 2015 - 10:53 AM
hah, I can't explain that, although I remember we first thought it was an air lock, so maybe that was the case and this has finally cleared it. Keep an eye on it, and let me know if it starts acting up again.
#165 phippsy
phippsy
  • 472 posts
Posted 15 August 2016 - 09:01 AM
Installing my heater and the plastic screws holding the blower are broken. Anyone know what size they are so I can replace them? Cheers
#166 fezzasus
Posted 15 August 2016 - 09:19 AM
They're M4.
If you replace with metal bolts. Make sure you don't over tighten. That's the reason I included plastic bolts
#167 phippsy
phippsy
  • 472 posts
Posted 15 August 2016 - 11:20 AM
Cheers, will go easy on tightening.
#168 martinroger
martinroger
  • 459 posts
Posted 22 November 2016 - 06:52 PM
Hey all, two questions :
- I have looked through the thread but haven't found the answer... is there anywhere we can buy the Mk2 heater ? Couldn't find it on Revotec either ...
- If one cannot buy it anymore, could someone take a picture of the bracket of the hot/cold cable on the Mk1 heater ? It is free-floating without a bracket on mine, I need to figure out where the fulcrum is.
#169 fezzasus
Posted 23 November 2016 - 07:38 AM
Only for sale via me, no units left. There *may* be a new version as I have had many requests this winter, but with other activities (headlights mostly) this won't occur until next year.
#170 martinroger
martinroger
  • 459 posts
Posted 23 November 2016 - 08:19 AM
You sir are a gentleman. I'll keep an eye out for a new version, in the meantime I guess I will take the old one out, seal it, change the air pipe and replace that pesky hot/cold cable by a servo control. Thanks for the swift reply !
#171 Stocky
Stocky
  • 35 posts
Posted 14 December 2016 - 11:34 PM
Is there somewhere people can put their name down to buy a new heater, should a new version come available? I would certainly be interested.
#172 chuno
chuno
  • 3,953 posts
  • Interests:Cars, Football (playing and watching)
Posted 13 February 2017 - 10:02 AM
Can i still buy this heater?
#173 nicollow
nicollow
  • 3,801 posts
Posted 25 June 2017 - 01:16 PM
Does anyone have the link to the new valve installation? Can't seem to find it on my shitty phone
#174 nicollow
nicollow
  • 3,801 posts
Posted 25 June 2017 - 01:47 PM
http://www.furtive.c...nstructions.pdf
