Rear Clam Removal
12 replies to this topic
#1 Jason
Jason
  • 1,327 posts
  • Interests:Trackdays, Walking, Photography
Posted 20 September 2012 - 12:55 PM
So I have a PDF guide. It says take the wheels off but can't see a reason that they can't be left on. Any advice or do they have to come off? Note rear arch liners already removed by previous keeper.
Edited by Јason, 20 September 2012 - 12:59 PM.
#2 JG
JG
  • 13,612 posts
Posted 20 September 2012 - 12:59 PM
you have to take arch liners out, which you can't do with wheels on. The reason you have to take liners out is that you can't get to the sill nuts or the fuse loom without doing so. All your interior is coming out too.
#3 Jason
Jason
  • 1,327 posts
Posted 20 September 2012 - 01:00 PM
Already off from the previous owner leaving off on last clam removal. So I can simply proceed with wheels on then.?
#4 techieboy
You need to remove them to remove/undo the arch liners and the bolts on the top of the sill section where it's attached to the rear clam. You'll also need the access to get the boot loom through the grommet in the top of the wheel arch. Wheels can then go back on.
#5 Jason
Jason
  • 1,327 posts
Posted 20 September 2012 - 01:03 PM
OK thanks so they come off as required thanks.. :D
#6 oakmere
oakmere
  • 2,143 posts
Posted 20 September 2012 - 01:42 PM
Just take one wheel off at a time and remove the required bolts then wheels back on before removing the clam
#7 JG
JG
  • 13,612 posts
Posted 20 September 2012 - 02:02 PM
its a lot easier with the wheels off.
#8 Jason
Jason
  • 1,327 posts
Posted 20 September 2012 - 05:12 PM
Left the wheels on in the end, was not any more difficult just because the arch liners were off already...
Now to figure out what's wrong with the engine...
Here it is does not look like your all nice an perfect..
Edited by Јason, 20 September 2012 - 05:16 PM.
#9 JG
JG
  • 13,612 posts
Posted 20 September 2012 - 05:59 PM
Looks fine from here :lol: Why did you buy another one?
#10 Jason
Jason
  • 1,327 posts
Posted 20 September 2012 - 06:07 PM
Well really wanted to have a play with one without taking mine off the road. But it does need a bit of TLC, a lot of scratches and bodges on it. Will put them all right once I tackle the engine.
#11 siztenboots
  • 26,613 posts
Posted 21 September 2012 - 08:10 AM
its a 2.2 , theres the problem
#12 FLD
Posted 21 September 2012 - 08:15 AM
Exactly. Any car thats bodged and broken should be a tubby. :D
#13 Jason
Jason
  • 1,327 posts
Posted 21 September 2012 - 08:55 AM
Haha very funny. I will happily take donations of other engines Turbo or otherwise... ;)
