Oil Leak From Z20Let
6 replies to this topic
#1 andywilson
andywilson
  • 547 posts
Posted 23 September 2012 - 04:23 PM
hi all
took the rear clam off yesterday to tackle a few jobs over winter. (along with a few upgrades i would suspect)
used the guide on here, very good. would have taken me a lot lot longer without it!
anyway. while pottering about i noticed an oil leak from this thing
looks like its coming from the hose rather than the plastic box thing (no idea what it is - crank case ventilation maybe?)
is it a well known fault with a simple fix or is it a new hose jobbie?
alsoooo
the oil filter area seems to have a bit of a coating of oil
in particlar the banjo bolt and pipe furthest away. is this the same hose as pictured in the first picture?
thanks, andy
#2 Nev
Posted 23 September 2012 - 05:53 PM
That hose is the feeds oil to/from the black plastic oil/water heat exhanger. Those pipes come up on eBay occasionallly if you are patient... The oil leak by your filter will likely be a poor seal on the banjos. Just try nipping them up first, clean the area, drive the car and see if the prob has gone. If not replace the copper washers on the banjo. If the problem persists after that let me know and I will give further advice :)
Edited by Nev, 23 September 2012 - 05:53 PM.
#3 andywilson
andywilson
  • 547 posts
Posted 23 September 2012 - 06:40 PM
hi nev i'll keep a look out on ebay for one of them pipes then, bit skint at the moment so will have to wait till one comes up cheap. i'll pop into vauxhall and get some new copper washers too, might as well replace them all while i've got good access! just need to find the part numbers now! i'll report back with my findings much appreciated andy
#4 craigb78
craigb78
  • 252 posts
Posted 23 September 2012 - 06:47 PM
my mate breaks astra turbos all the time. im sure he will have this pipe for cheap here is his site give him a text: http://www.torquemotors.co.uk/
#5 andywilson
andywilson
  • 547 posts
Posted 23 September 2012 - 06:55 PM
hi there thanks for the details although i'd rather replace with new. might cost a bit more, but i dont want to have to repeat the job again in 6 months time! for anyone thats interested part number for the hose/pipe is 9042375. and the copper washers are 11076852 cheers, andy
#6 Nev
Posted 24 September 2012 - 07:21 AM
Andy, another thing to check is to take the oil filter off. Then check that the screw in adapter/sandwich plate that mounts to the oil pump is mated fully and is sealing properly. I am not 100% sure that standard VXT has this plate BTW, as I get consuded between Z20LET/H these days. Worth checking though.
#7 siztenboots
  • 26,613 posts
Posted 24 September 2012 - 07:28 AM
why is there a huge bit of studding and a nyloc on your inlet manifold
