Help Please
#21
Posted 05 October 2012 - 10:29 AM
#22
Posted 05 October 2012 - 10:34 AM
#23
Posted 05 October 2012 - 10:36 AM
Edited by NickB777, 05 October 2012 - 10:37 AM.
#24
Posted 05 October 2012 - 10:53 AM
#25
Posted 05 October 2012 - 11:07 AM
#26
Posted 05 October 2012 - 12:54 PM
#27
Posted 05 October 2012 - 12:58 PM
#28
Posted 05 October 2012 - 12:59 PM
cheers Mike, did I give you the 6 rib belt with the harrop? I found a 1275 but am having trouble fitting it. I am checking the run of the belt
No as I only run 5 rib on the bottom pulley and alternator. I do have a suitable length 5 rib.
#29
Posted 05 October 2012 - 01:03 PM
#30
Posted 05 October 2012 - 03:06 PM
#31
Posted 05 October 2012 - 03:14 PM
Is it a standered cobalt ss size the 6 rib Double sided ?I have a US double sided 6 rib belt. Any good?
#32
Posted 05 October 2012 - 04:00 PM
#33
Posted 05 October 2012 - 04:02 PM
Maybe it's me but is there any special way to get these belts on? I have a couple of things left, the fuel rail small pipe goes where? and the tb pipe also where?
put round the crank pulley then feed it the normal way then lift the tensioner up using a 3/8 ratchet then put onto the top sc pulley
if you mean the fpr pipe then it goes in the end of the fuel rail and into the manifold located in the middle of the intake mani
not sure what you mean by tb pipe? charcoal canister pipe? if so then round the back of the tb
#34
Posted 05 October 2012 - 04:03 PM
sh*t of course blond moment lolwont fit lee, we dont have air con etc
#35
Posted 05 October 2012 - 05:09 PM
Than Joe I managed it in the end, real pain. Almost there when i turned it on the dash went nuts ,I will try tomorrow with some new info I got from Jon as to what they did to the wiring. Just pray it works
anyone got a diagram (in english) of the x2 (blue plug) pin layout I need to change pin 8 to pin 12, or it might actually be pin 12 to pin 8 it was used for switching for the fuel pump on the z20let loom
Edited by NickB777, 05 October 2012 - 05:18 PM.
#36
Posted 06 October 2012 - 11:14 AM
#37
Posted 06 October 2012 - 11:31 AM
Z22SE ecu feeds the pump relay with a 12v signal:
White violet wire from ecu through pin 8 of the X2 connctor to connection 2 of the fuel pump relay. Relay pin 4 is to ground.
LET is different, as the ecu switches to ground: http://www.speedster... Z20LET - 2.pdf
(Relay pin 4 switched to ground through X2-8, Wh-Vt wire. Relay pin 2 has +12v through K18.)
Edited by Exmantaa, 06 October 2012 - 11:39 AM.
#38
Posted 06 October 2012 - 12:31 PM
Edited by NickB777, 06 October 2012 - 12:32 PM.
#39
Posted 06 October 2012 - 12:52 PM
#40
Posted 06 October 2012 - 12:58 PM
