x2 pin 12 green/pink go to 86
.5 brown goes from 85-87
large brown goes from 87 out
brown/pink goes from 30 to x2 pin 1
the k16 fuel pump relay seems to be wired as z22se diagram and pins on x2 agree
^^ is that from Engine relay K18??
Posted 06 October 2012 - 12:58 PM
Posted 06 October 2012 - 12:59 PM
Posted 06 October 2012 - 01:05 PM
Posted 06 October 2012 - 01:08 PM
Edited by NickB777, 06 October 2012 - 01:10 PM.
Posted 06 October 2012 - 01:25 PM
Posted 06 October 2012 - 01:29 PM
Posted 06 October 2012 - 01:32 PM
Edited by Exmantaa, 06 October 2012 - 01:41 PM.
Posted 06 October 2012 - 01:43 PM
Edited by NickB777, 06 October 2012 - 01:45 PM.
Posted 06 October 2012 - 02:00 PM
Posted 06 October 2012 - 02:08 PM
Edited by NickB777, 06 October 2012 - 02:08 PM.
Posted 06 October 2012 - 02:14 PM
Posted 06 October 2012 - 02:26 PM
Posted 06 October 2012 - 02:42 PM
Posted 06 October 2012 - 03:34 PM
Posted 06 October 2012 - 03:48 PM
OBD will not tell you much.
Posted 06 October 2012 - 03:56 PM
The Stack goes blank
Posted 06 October 2012 - 04:32 PM
*** as it is now when you turn the ignition on you get the normal lights but the the lcd display goes blank after a few seconds
Posted 06 October 2012 - 04:40 PM
green/pink is the OV supply from ecu to power the relay coil on K18, so if not connected the relay would just do nothing - which appears to be what is still happeningmy concern is when i removed the extra relay I left the green/pink wire isolated because I didn't see the other end which had beed cut well back in the loom tape. I then tried the car and I am concerned I may have done some damage somewhere, ecu? as it is now when you turn the ignition on you get the normal lights but the the lcd display goes blank after a few seconds
Edited by vocky, 06 October 2012 - 04:59 PM.
Posted 06 October 2012 - 04:51 PM
green/pink is the +12v supply from ecu to power the relay coil on K18, so if not connected the relay would just do nothing - which appears to be what is still happening
Posted 06 October 2012 - 04:58 PM
