Are there any local owners who could lend you their light clusters on MoT day?the light output is completely wrong on one of the headlights, I can't adjust it either as the adjuster seems to do nothing.. so yes I can drive with them but won't pass MOT
Why can't you pass an MOT? The individual projectors are all E-coded so still legal without a cover.I still have my old ones without any lense cover but they won't pass MOT, but I won't drive until late april maybe if weather is good be then.
Replacement Headlights - Gauging Interest
#221
Posted 03 January 2014 - 09:31 PM
#222
Posted 03 January 2014 - 09:38 PM
if Fezzasus don't have something ready until May then I might be able to lend from some local owners I think.
#223
Posted 07 January 2014 - 11:09 PM
Forget HID's. We need lasers.
[color=rgb(51,51,51);font-family:Georgia, serif;font-size:15px;font-style:italic;]The powerful laser diodes are significantly smaller than LED diodes; they are only a few microns in diameter. Illuminating the road for a distance of nearly 500 meters (1,640 ft), the laser high-beam light has approximately twice the lighting range and three times the luminosity of LED high beam lights. [/color]
#224
Posted 07 January 2014 - 11:23 PM
#225
Posted 07 January 2014 - 11:32 PM
#226
Posted 08 January 2014 - 12:28 AM
#227
Posted 08 January 2014 - 09:59 AM
one of mine is the same , main beam is a searchlightthe light output is completely wrong on one of the headlights, I can't adjust it either as the adjuster seems to do nothing.. so yes I can drive with them but won't pass MOTWhy can't you pass an MOT? The individual projectors are all E-coded so still legal without a cover.I still have my old ones without any lense cover but they won't pass MOT, but I won't drive until late april maybe if weather is good be then.
#228
Posted 08 January 2014 - 10:03 AM
#229
Posted 08 January 2014 - 10:45 AM
Might be some scope to run a pair of prototypes...
#230
Posted 08 January 2014 - 10:49 AM
#231
Posted 08 January 2014 - 10:58 AM
Plan to have brackets available at end of Jan, will allow for testing of functionality of headlights without plastic lens cover fitted before starting the second stage of design to produce the plastic shrouds.
#232
Posted 08 January 2014 - 02:00 PM
I never used to think the VX headlights were all that bad, I just thought people just liked moaning!
Until that is I tried to drive the VX the other night after being so comforatble in the Navara, at one point the thought of having to wait until sunlight went through my head!
Probably doesn't help that my drivers side dipped beam sits considerably lower than the pax one, tried adjusting, nothing.
I could help with that if needed, I'd imagine I'm not all that far from you either, maybe 30 mins max.
#233
Posted 08 January 2014 - 02:03 PM
Could be useful. My VX will be going in for a respray in Feb so i'll lose a couple of weeks of testing, plus the more hours tested the better. The prototypes won't be initially pretty, that's the final step. This will be purely to confirm functionality and durability.
If you haven't seen it already, I've included photos of the output from the new xenon projectors and old halogen units, you can see the original units are very poor in terms of light output. The beam pattern and distribution is also poor, which is why just fitting xenon bulbs doesn't fix much.
#234
Posted 08 January 2014 - 02:27 PM
Hi Fezz,
Keep going with the good work!!
I also hope to be ready with the covers soon.
In fact, the only thing missing is getting the heat and curing porcess right to minimise the bonding gap...
So wiht our both stuff, there will finally be a full solution to get around the OE lights
Edited by GF ORCE8, 08 January 2014 - 02:28 PM.
#235
Posted 08 January 2014 - 05:05 PM
I have been keeping this an eye on this, just in the background! I currently have HID's fitted so it would be a good comparison between all three as well
Have you seen this site? Not sure where you get parts from but its rated highly on other forums I'm on, albeit american.
If you have an english supplier of similar parts I'd be interested in knowing who it is, I'm looking at fitting a set of projectors into the Navara's headlights at some point this year, don't really want to fork up postage/import costs from the US for something that might go incredibly wrong.
#236
Posted 08 January 2014 - 05:11 PM
I have a supplier, however only have one set. The issue you'll have using that website is that the US beam pattern is different and will all be LHD cut off. I am using Bosch 3"D3S projectors with OEM quality balasts. I can add a pair onto the next order if you want.
#237
Posted 08 January 2014 - 07:20 PM
Hi Fezz,
Could you let me know as soon as you have a set of lenses that fit correctly. I don't care how they look, as long as they have the correct shape
#238
Posted 08 January 2014 - 08:10 PM
That website does offer a RHD version, so I assume they ship all over the show.
I'll PM you regarding the projectors and ballasts.
Edited by Rusty789, 08 January 2014 - 08:10 PM.
#239
Posted 12 January 2014 - 12:13 PM
I think thats the site some guys on my missus M3 forums are using to replace and upgrade their projectors..they rate them highly..I have been keeping this an eye on this, just in the background! I currently have HID's fitted so it would be a good comparison between all three as wellIf you haven't seen it already, I've included photos of the output from the new xenon projectors and old halogen units, you can see the original units are very poor in terms of light output. The beam pattern and distribution is also poor, which is why just fitting xenon bulbs doesn't fix much.
Have you seen this site? Not sure where you get parts from but its rated highly on other forums I'm on, albeit american. If you have an english supplier of similar parts I'd be interested in knowing who it is, I'm looking at fitting a set of projectors into the Navara's headlights at some point this year, don't really want to fork up postage/import costs from the US for something that might go incredibly wrong.
#240
Posted 14 January 2014 - 07:01 AM
Hi Fezz,
Yeah, sure!
Just have brought a set of OE clusters to the producer of the lens covers, so that they can refine the fitment.
As soon as I´l have something here that clears, I will send a set over to you!
Also tagged with one or more of these keywords: headlights, headlight upgrade, headlight replacement
General Discussion →
VX220 Discussion →
Protective Film For HeadlightsStarted by Sutol , 08 Sep 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
VX220 Discussion →
Headlight Costs.Started by stefcaz94 , 09 Feb 2014 ![]() |
VX220 Discussion →
First Time That's Happened....Started by KurtVerbose , 30 Jan 2014 ![]() |
VX220 Discussion →
Headlight Gremlin - Anyone Have Any Idea's?Started by Ash , 09 Oct 2013 ![]() |
