I'm confused. Are you guys working together to create this unit? (i.e. housing/lights from fez, lens covers from GF?)
Replacement Headlights - Gauging Interest
#241
Posted 14 January 2014 - 10:19 AM
#242
Posted 14 January 2014 - 10:28 AM
No point reinventing the wheel. If there are lens covers available then I would always prefer to use those so I can focus on other areas.
#243
Posted 14 January 2014 - 10:40 AM
Ahh okay.
I only mentioned it because you originally said you were trying to keep the costs down to £500 for a pair. But considering GF wants £300 just for the lenses, I'm guessing that price is going to go up considerably.
#244
Posted 14 January 2014 - 10:44 AM
Ahh okay.
Costs will be managed, please try to avoid jumping to these conclusions before I can provide the full details.
#245
Posted 14 January 2014 - 11:48 AM
£500 for the pair sounds cheap to me, around 800 seems fair, but ofc cheaper the better!
Edited by Gilgamesh, 14 January 2014 - 11:48 AM.
#246
Posted 14 January 2014 - 04:11 PM
#247
Posted 14 January 2014 - 04:20 PM
The oem rears are really horrid
really?
I like the look of them.
#248
Posted 14 January 2014 - 04:32 PM
I think it would be a big mistake to make any replacement light unit too different from the original design. I never had an issue looks wise other than them having very poor performance.
#249
Posted 14 January 2014 - 04:44 PM
Totally agree. We need a like for like replacement or as near as looks wise first of all.
#250
Posted 14 January 2014 - 08:15 PM
#251
Posted 14 January 2014 - 08:17 PM
Fez, do you plan to make the housing by injection moulding? If needed I have good connections with chinese tooling and part suppliers. With this kind of low volume production a lot of money may be saved by using cheeper steel or aluminium for the tool...
I do, I will contact you when I get back from NYC to discuss this if you are willing to provide me the details of your connections.
Thanks
#252
Posted 14 January 2014 - 08:31 PM
My suggestion for design would be to remove the separate highbeams and go with a bi-xenon solution with DRL position light. That should open up space for more freedom in design and packaging of the components. Take a look at newer Ferrari's like F430 and onward for reference
THAT sounds interesting
imo as long as the headlights works as they should I don't mind with a more (modern/up to date) style
Edited by Gilgamesh, 14 January 2014 - 08:32 PM.
#253
Posted 14 January 2014 - 08:41 PM
Thats fine, I work with them almost daily so I can initiate the collaboration between you when the time comes.I do, I will contact you when I get back from NYC to discuss this if you are willing to provide me the details of your connections. ThanksFez, do you plan to make the housing by injection moulding? If needed I have good connections with chinese tooling and part suppliers. With this kind of low volume production a lot of money may be saved by using cheeper steel or aluminium for the tool...
#254
Posted 14 January 2014 - 09:01 PM
i was actually thinking of something similar, however it could well work out as two different versions; ones that look the same as currently and one that is a modern replacement.
#255
Posted 14 January 2014 - 10:14 PM
#256
Posted 14 January 2014 - 10:17 PM
#257
Posted 14 January 2014 - 10:20 PM
the problem we have here is..... the possibilities are endless...... everyone has different tastes........and to keep costs down only one design would be efficient at doing that...... if some want this kind, some that one another its going to be a no go..... i'd be happy, overjoyed even for an identical light that actually lets you see more than 20 feet infront of you and the sooner that can happen the very much better...
Edited by dumfunk, 14 January 2014 - 10:21 PM.
#258
Posted 14 January 2014 - 10:24 PM
#259
Posted 18 January 2014 - 08:26 PM
Are you going to copy the inscriptions of the original lens covers to get in the new headlights the appearance of a 100% OEM product?Hi Fezz, Keep going with the good work!! I also hope to be ready with the covers soon. In fact, the only thing missing is getting the heat and curing porcess right to minimise the bonding gap... So wiht our both stuff, there will finally be a full solution to get around the OE lights
#260
Posted 19 January 2014 - 10:36 AM
Yes, all will be on the covers.
Also they will eb ahrdcoated against scratches like the OEs.
Just check out the thread for all teh details:
http://www.vx220.org...ket-production/
Edited by GF ORCE8, 19 January 2014 - 10:36 AM.
Also tagged with one or more of these keywords: headlights, headlight upgrade, headlight replacement
General Discussion →
VX220 Discussion →
Protective Film For HeadlightsStarted by Sutol , 08 Sep 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
VX220 Discussion →
Headlight Costs.Started by stefcaz94 , 09 Feb 2014 ![]() |
VX220 Discussion →
First Time That's Happened....Started by KurtVerbose , 30 Jan 2014 ![]() |
VX220 Discussion →
Headlight Gremlin - Anyone Have Any Idea's?Started by Ash , 09 Oct 2013 ![]() |
Bing (1)
