Replacement Headlights - Gauging Interest
headlights headlight upgrade headlight replacement
1388 replies to this topic
Poll: Replacement headlights (352 member(s) have cast votes)
Interest in replacement headlights
  1. As an upgrade (eg legal, high quality xenons) (173 votes [49.15%])
    Percentage of vote: 49.15%
  2. As a current replacement (to currently damaged/weathered headlights) (103 votes [29.26%])
    Percentage of vote: 29.26%
  3. As potential replacement (71 votes [20.17%])
    Percentage of vote: 20.17%
  4. Not interested (5 votes [1.42%])
    Percentage of vote: 1.42%
Vote Guests cannot vote
#641 fezzasus
Posted 28 July 2016 - 03:10 PM
Would also be really interested in this, likewise would need to look like OEM! My o/s light has cracked plastic around light and rattles and the n/s steams up real bad so would be really interested.
Why do they have to have washers? Don'y like the sound of that as then it is not looking OEM!
I just want a replacement light until which look original to do direct replacement with, but brighter if possible.
Photos are further up the page.
Washers will be optional as they are not required for UK MOT (can only fail if washers are fitted and non-functional), however other countries require washers for xenon lamps.
#642 Rusty789
Rusty789
    Ginger Ninja
  • 2,120 posts
Posted 28 July 2016 - 07:03 PM
So in short, If i take pre-orders now I can deliver working headlamps in approx 6 weeks, however I won't be able to show final images of the rear of the headlamp until delivery.
I don't really care what the back looks like! :D the main thing (and I'm sure this is the case for most others) is the light output, which should be much better than standard.
I just don't want to miss out, then there never be a second batch (highly unlikely, I'd like to imagine) and be stuck with the standard headlights...
#643 gaffer1986
gaffer1986
  • 4,408 posts
Posted 28 July 2016 - 08:56 PM
Are they all going to be carbon fiber look then?
#644 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 July 2016 - 08:10 AM
they are actual carbon and there is no reason you cant paint them
#645 techieboy
Posted 29 July 2016 - 08:29 AM
I most definitely will be painting them. Well, possibly Full Dipping them anyway. I've even been practicing trying to do it in a similar style to OEM with matt black main body and in my case matt anthracite light shrouds (as I wanted something darker than silver but trying to avoid a turdo replica). Proper pain in the arse as so far every time I try to mask either one bit or the other, the masking tape invariably pulls away some of the FullDip when removing and screws things up. May mean I have to go with the permanent option of paint instead but whatever, I can't live with the carbon finish. :wacko:
#646 gaffer1986
gaffer1986
  • 4,408 posts
Posted 29 July 2016 - 08:35 AM
Agreed, I've never been much of a fan of carbon fibre. About the only time I've liked the look of it is in r2mlb's car. I have the same carbon inside my car but don't like it, I can't understand why.
#647 pete-r
pete-r
  • 2,771 posts
Posted 29 July 2016 - 08:38 AM
I would look at plastidip if you don't want carbon, so you can do it DIY, you can cleanly remove it if you ever wanted to sell them on or change colour.
#648 fezzasus
Posted 29 July 2016 - 09:42 AM
Matt black will be an option
#649 humberty
humberty
  • 50 posts
Posted 29 July 2016 - 09:44 AM
If you plastydip then the headlamp cover need to be removed and then glued back again? Are these units coming with the clear cover lens ? Sent from my SM-G920F using Tapatalk
#650 pete-r
pete-r
  • 2,771 posts
Posted 29 July 2016 - 09:48 AM
That's right, but techie was talking about painting them anyway so would be no difference. I'm a chav so carbon the way for me!!
#651 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 29 July 2016 - 10:42 AM
Best option ;-)
#652 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 July 2016 - 11:44 AM
winning
#653 techieboy
Posted 29 July 2016 - 11:45 AM
  I've FullDipped (meant to be better than Plastish!t and many more colour options) a fuggered spare to see how well it works for that very reason. 4 coats of black all over. Then I went with 5 coats of anthracite - screwed the final coat when I changed the spray nozzle :rolleyes: - for the shrouds (I prefer the contrast but would like something darker than the standard NA silver just not wannabe turdo style) which ties in with my screen surround and wheels. Problem is, masking the main body of the lights to spray the shrouds meant when I carefully started peeling it off, it pulled some of the black away or even separated the layers as well and ruined the effect.   So unless I find some better masking solution, I'll probably end up having to use paint (probably better anyway as better choice of colours).
#654 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 29 July 2016 - 06:24 PM
Will they be for both right and left side driven cars? Whats the price estimation for a set?
#655 fezzasus
Posted 01 August 2016 - 07:47 AM
Finally sat down with all my supplier costings to put together total cost and final purchase price.
Headlight details:
- price is for a pair of front headlights, fully assembled
- available as both RHD and LHD. No price difference.
- Full one piece carbon fibre enclosure (available gloss or matt black)
- Headlamps as follows;
    + 3 inch Bi-xenon projector providing dipped beam and non-flash main beam (however can also be configured for H7 halogen if needed)
    + 90 mm halogen main beam unit with sidelight (same as OEM), providing main beam (including flash)
    + same as original indicator unit
Cost
£1300, £650 upfront cost, £650 payable prior to delivery
Production time
approximately 6 weeks, however this is small volume production at a carbon fibre site supplying motorsport, so rate depends on other work. At the moment the production time will be quick (summer shut down for F1 teams), however once into October it'll be very difficult to get any production time.
So.. who's in?
#656 oggster
oggster
  • 886 posts
  • Interests:Staying alive 😉
Posted 01 August 2016 - 08:15 AM
Me , rhd, full one piece carbon fibre ,gloss,with the 90mm same as oem please ...you have my lenses from the crowd funding so I am assuming you will fit these Tom? Let me know how to pay thanks .. Sent from my iPhone using Tapatalk
#657 Mattias
Mattias
  • 300 posts
Posted 01 August 2016 - 08:20 AM
I'm in for lhd carbon.
#658 gaffer1986
gaffer1986
  • 4,408 posts
Posted 01 August 2016 - 08:25 AM
What about alignment?
#659 fezzasus
Posted 01 August 2016 - 08:26 AM
Good point, forgot to add that. Retained lenses from the crowdfunding entitle a £165 discount.
#660 wizzard8
wizzard8
  • 78 posts
Hi Tom One set lhd carbon for me please
Also tagged with one or more of these keywords: headlights, headlight upgrade, headlight replacement
