They'll be with you before May.
Right now i can supply the left hand side. I'm waiting for the rear enclosures to be completed for the right hand side.
Posted 24 March 2017 - 03:36 PM
Posted 24 March 2017 - 07:27 PM
What's your final price and specs?They'll be with you before May. Right now i can supply the left hand side. I'm waiting for the rear enclosures to be completed for the right hand side.
Posted 24 March 2017 - 07:42 PM
Thanks for the update Tom !They'll be with you before May. Right now i can supply the left hand side. I'm waiting for the rear enclosures to be completed for the right hand side.
Posted 16 April 2017 - 08:46 PM
Posted 04 May 2017 - 10:20 AM
Posted 04 May 2017 - 10:39 AM
Hopefully the first people to receive them will be able to provide updates in a week or two.
Posted 04 May 2017 - 01:14 PM
Awesome. Is there a list for a second batch? Can't find anything...Hopefully the first people to receive them will be able to provide updates in a week or two.
Posted 04 May 2017 - 01:33 PM
I'm not taking any orders yet. I need to get the first batch out before getting distracted
Posted 04 May 2017 - 01:48 PM
Alright, thanks for the heads up! I'll keep them eyes peeled then. I suppose there aren't more first batch pairs available?I'm not taking any orders yet. I need to get the first batch out before getting distracted
Edited by martinroger, 04 May 2017 - 01:49 PM.
Posted 05 May 2017 - 08:52 PM
Posted 05 May 2017 - 08:54 PM
I guess this means they'll be shipping soon, if not already! Tom will you be shipping them pre-levelled as such or will we have to adjust the alignment? However, I won't be fitting mine before the Hoon for obvious reasons! I'll do a decent comparison as soon as I get my hands on them though!
Definitely keen on seeing the final product. Fez, do you think the second batch can make it before August ? Not wanting to distract you !
Posted 10 May 2017 - 10:24 PM
Bixenon is way more powerful.
Yeah, that's the overwhelming factor, it doesn't matter if you go for halogen or LED as the bixenon main beam is significantly stronger. It comes down to how it looks.
Out of curiosity, what's the power rating and lumen rating of those LEDs ?
Posted 24 May 2017 - 08:28 PM
Anyone received theirs ? Any feedback/updates ?
Posted 29 May 2017 - 03:21 PM
Posted 31 May 2017 - 10:04 PM
any update yet?
Last I heard from Tom was that the expected delivery date is the middle of the year. I'm taking that to be the beginning of July.Anyone received theirs ? Any feedback/updates ?
Yeah, that's the overwhelming factor, it doesn't matter if you go for halogen or LED as the bixenon main beam is significantly stronger. It comes down to how it looks.Bixenon is way more powerful.
Posted 31 May 2017 - 10:07 PM
any update yet?
Are you on the lucky list of first wave ? If so I will be keen on your feedback. The question about the power rating was just to evaluate how things got handled... cause usually full beam LED units have some fan of some sort at the back. Which in my experience is a just another potential failure source, albeit a costly one ! I suspected the LED unit here was derived from a 90mm fog light base, just wanted to make sure, really.
Cheers though !
Posted 01 June 2017 - 06:20 AM
the LED high beam is now a supplemental unit as the main beam is now a bixenon unit. This means that the dipped beam also handled high beam when the dipped beams are on, leaving the LED unit only handling flash situations in daylight. As a result it's relatively low power (but as you can see from the previous photos, it's comparable to the halogen unit found in the original lamps)
Posted 01 June 2017 - 06:55 AM
Thanks Tom!the LED high beam is now a supplemental unit as the main beam is now a bixenon unit. This means that the dipped beam also handled high beam when the dipped beams are on, leaving the LED unit only handling flash situations in daylight. As a result it's relatively low power (but as you can see from the previous photos, it's comparable to the halogen unit found in the original lamps)
Posted 01 June 2017 - 07:36 AM
Another update.
Rear covers are in full production but rate is around 1 per day, i'm assembling units as they go and sequencing them from most similar to prototype (gloss carbon, LED main beam) to least (different paint options, halogen units). I've made a number of changes to the production units from the prototype units which include (but are not limited to):
- use of standard sized grommets to cover adjustments where possible (now 20mm blind grommets as used on socket back boxes - should mean anyone can source spares at low cost)
- uprated wiring for xenon unit
- addition of anchor mount on xenon unit to prevent vibration on rough surface
Posted 01 June 2017 - 07:39 AM
General Discussion →
VX220 Discussion →
Protective Film For HeadlightsStarted by Sutol , 08 Sep 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
VX220 Discussion →
Headlight Costs.Started by stefcaz94 , 09 Feb 2014 ![]() |
VX220 Discussion →
First Time That's Happened....Started by KurtVerbose , 30 Jan 2014 ![]() |
VX220 Discussion →
Headlight Gremlin - Anyone Have Any Idea's?Started by Ash , 09 Oct 2013 ![]() |
