Replacement Headlights - Gauging Interest
#81
Posted 28 January 2013 - 07:06 PM
#82
Posted 28 January 2013 - 08:17 PM
Edited by Gilgamesh, 28 January 2013 - 08:24 PM.
#83
Posted 28 January 2013 - 08:18 PM
#84
Posted 28 January 2013 - 08:19 PM
Fezzasus, if you pull this off it'll be brilliant - no pun intended. Definitely in for a set. I don't think they'd pass the Swiss mot nazi, but I'll just swap with the old set.
why would they not pass MOT?
#85
Posted 28 January 2013 - 08:47 PM
great news, I know if you have xenon lights you need to have washers, but will it be possible not to use washers with the xenon headlights you make?
They will have washers, the feed for the windscreen will be split and go into the back of the headlight unit.
#86
Posted 28 January 2013 - 08:52 PM
aha ok, if I understand it correct the washers will be "built-in" in the headlights?
Edited by Gilgamesh, 28 January 2013 - 08:54 PM.
#87
Posted 28 January 2013 - 08:54 PM
That's right.
#88
Posted 28 January 2013 - 08:55 PM
#89
Posted 28 January 2013 - 08:56 PM
That's right.
ok, thanks, you still aiming for £500 for a pair of xenon headlights?
#90
Posted 28 January 2013 - 08:57 PM
Is it still an MOT fail as the car didn't come from factory with xenons?
no problem with MOT here even though I use HID xenons on my car, many of the MOT men don't know anything about this car
#91
Posted 28 January 2013 - 08:58 PM
no problem with MOT here even though I use HID xenons on my car, many of the MOT men don't know anything about this car :)/>
I'd be ok with my friendly mot tester. Just others might hit a brick wall if the guidelines aren't met.
#92
Posted 28 January 2013 - 09:01 PM
It needs to meet three requirements:
1. correct beam pattern (basically projector lenses, not the diffracting type)
2. washers
3. levelling
The latter one is not required for cars with restricted carrying capacity.
#93
Edited by Gilgamesh, 28 January 2013 - 09:03 PM.
#94
Posted 28 January 2013 - 09:04 PM
2. washers
3. levelling
Well hurry up then. It's not as if you've got enough on your plate.
#95
Posted 28 January 2013 - 09:11 PM
#96
Posted 28 January 2013 - 09:18 PM
2. washers
3. levelling
Tell me about it, although i've got the heaters under control a bit more - now down to a batch process. I can actually see the dining room table now.
#97
Posted 28 January 2013 - 09:24 PM
2. washers
3. levelling
Well hurry up then. It's not as if you've got enough on your plate. ;)/>
So you've moved all the wads of cash to the floor then?
#98
Posted 28 January 2013 - 09:27 PM
This sound very promising and again you have done the deeds. Looking forward to the outcome. Mainly to stick 2 fingers up at Vauxhall! The other is this sort of thing could reduce the number of rotten off cars with little more then headlight damage.
For these cars to last for another 10 years it needs (filthy rich) people like fezzas to make essential parts.
The mechanical and suspension side is covered by lotus and the Astra graveyard. However lights, clams and body panels need to be pushed and built to a good standard.
#99
Posted 28 January 2013 - 09:39 PM
I wish, I find my suppliers have many more places to keep my cash than I do
#100
Posted 28 January 2013 - 09:57 PM
Let me be quite clear here, I'm talking about the Swiss Mot guy, not the British. The Swiss guy will fail if the engine is not clean enough never mind aftermarket lights.
Fezzasus, you will be doing them LHD also won't you? If not you should - they go for a fortune second hand.
Also tagged with one or more of these keywords: headlights, headlight upgrade, headlight replacement
General Discussion →
VX220 Discussion →
Protective Film For HeadlightsStarted by Sutol , 08 Sep 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
VX220 Discussion →
Headlight Costs.Started by stefcaz94 , 09 Feb 2014 ![]() |
VX220 Discussion →
First Time That's Happened....Started by KurtVerbose , 30 Jan 2014 ![]() |
VX220 Discussion →
Headlight Gremlin - Anyone Have Any Idea's?Started by Ash , 09 Oct 2013 ![]() |
Bing (2)
