Replacement Headlights - Gauging Interest
#121
Posted 19 March 2013 - 11:46 PM
#122
Posted 20 March 2013 - 08:12 AM
#123
Posted 20 March 2013 - 08:20 AM
Edited by Gilgamesh, 20 March 2013 - 08:20 AM.
#124
Posted 20 March 2013 - 08:22 AM
agree, just keep it simple and cheap
everything that is better than the OEM headlights is fine
It's not obvious from the photo I put up but the new projectors have a 3" diameter rather than 2.5", this means better light distribution. It's also a cheaper option than the OEM size as it's more common.
#125
Posted 20 March 2013 - 02:07 PM
#126
Posted 20 March 2013 - 02:37 PM
Any idea when these will be on the market? I'm desperate for a front drivers light as I can't pass an MOT with the bulb flopping about as it is now.
Not in time for you i'm afraid. PM Bargi - I know he had similar issues.
If you're feeling ambitious, you can crack open the back and epoxy the lens back in place. I would suggest lowest temp in the oven for 15 minutes, then put a flat blade screw driver between the two plastic sections to prize apart. It will probably take more than one go heating it up.
#127
Posted 20 March 2013 - 02:47 PM
#128
Posted 20 March 2013 - 02:58 PM
#129
Posted 21 March 2013 - 07:11 PM
Still looking a bit pikey because it's using an old enclosure as a template (i'm working out the new projector and ancillaries mounting points).
But this is a headlight with a 3" bosch projector in, excited yet?
I'll get it wired up and working over the weekend to give you an idea of light output vs standard (and standard with Xenon). Just keep buying heaters, otherwise i'm not going to be able to afford to do this!
Edited by fezzasus, 21 March 2013 - 07:13 PM.
#130
Posted 21 March 2013 - 08:14 PM
#131
Posted 21 March 2013 - 09:06 PM
#132
Posted 21 March 2013 - 09:34 PM
Well I like the look of the NA ones, so i'll get a small number masked off and sprayed silver.
ok, good to have options
#133
Posted 21 March 2013 - 09:43 PM
#134
Posted 21 March 2013 - 09:44 PM
#135
Posted 21 March 2013 - 10:31 PM
#136
Posted 22 March 2013 - 12:26 PM
I look forward to prices Tom
And the finished article. If the heaters are anything to go by these will be cracking bits of kit. Interested to see light output differences as well.
#137
Posted 22 March 2013 - 12:34 PM
#138
Posted 25 March 2013 - 03:24 PM
#139
Posted 25 March 2013 - 06:27 PM
#140
Posted 25 March 2013 - 06:41 PM
Also tagged with one or more of these keywords: headlights, headlight upgrade, headlight replacement
General Discussion →
VX220 Discussion →
Protective Film For HeadlightsStarted by Sutol , 08 Sep 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
VX220 Discussion →
Headlight Costs.Started by stefcaz94 , 09 Feb 2014 ![]() |
VX220 Discussion →
First Time That's Happened....Started by KurtVerbose , 30 Jan 2014 ![]() |
VX220 Discussion →
Headlight Gremlin - Anyone Have Any Idea's?Started by Ash , 09 Oct 2013 ![]() |
