Twin Fan Charge Cooler Rad Wiring
8 replies to this topic
#1 nicollow
nicollow
  • 3,801 posts
Posted 06 October 2012 - 10:55 PM
I take it that when you wire up the twin fan CC rad, you just parallel up the connectors and splice them into the old connector? Presumably the wiring/fuse can take it?
#2 Rally
Rally
  • 650 posts
Posted 06 October 2012 - 11:22 PM
Yes. I seem to remember that I had to cut off the connector from the old single fan to re-use with the new twin fans. Double check they work and blowing in the right direction before you re-assemble everything!
#3 nicollow
nicollow
  • 3,801 posts
Posted 06 October 2012 - 11:40 PM
Thats what I was thinking, thanks for the confirmation ;)
#4 siztenboots
Posted 19 June 2019 - 12:46 PM
the CC Spal twin fan wiring tails are a bit short , and the routing of the two looms around the radiator cores seems a bit lacking for some holes to get them into the battery compartment to the original connector.
how does the original single pair of wires snake through , is there a hole in the rad surround set for this?
#5 The Batman
Posted 19 June 2019 - 03:16 PM
Cut the plug and tails off the original fan and then connect that to the new fans
#6 siztenboots
Posted 26 June 2019 - 10:58 AM
don't have the old fan tail and plug , does anyone know the plug manufacturer?
/edit
been to have a second look round , the fan is a PED25 , indicators PED23 , seems to be a common Delphi Packard type plug
#7 chris_uk
Posted 29 June 2019 - 07:40 AM
Make sure you check the direction of the fans, you can make them come on by bridging the fan relay.
#8 siztenboots
Posted 29 June 2019 - 11:12 AM
yes, I remember Nickb777 had his wired up . The 3mm2 cable has arrived this afternoon so off to dig out the crimping tools to make an extension loom and route the cable to avoid trapping it.
#9 chris_uk
Posted 29 June 2019 - 01:28 PM
You shouldnt need to make a loom or extend anything, you orientate the fans so the wires run closest they can to the original plug and join them up. There should be ample length.
