Posted 29 October 2012 - 03:57 PM
Here is a list of receipts I have for the car to give anyone an idea of what sort of spending and care the car has had.
Vauxhall VX220 Spec.
Gas Flowed throttle Body £150-00
Coutenay silicon hose Code 80SHKVXT £51-95
Courtenay Intake pipe £109-45
Demon Tweeks Cool Air Tube Heat Shield £88-87
Thorney M/S Carbon Rear Diffuser £353-68
Courtenay High Flow Enlarged Plenum Code CSHFEPK3 £139-90
Regal Breather Hose and check over £63-25
Larini Full Exhaust System £1355-62
Courtenay Gearbox Breather Kit Code GBKPACS
£117-90
Sparco Carbon Fibre Pedals £38-00
Carbon Lower Centre Consul £60-00
Carbon Fibre Dash Plates £125-00
Carbon Fibre Gear Knob £30-00
Regal Underdrive Pulley £132.99
Clutch Release Bearing £100-00
Sachs Clutch Plate & Housing £597-00
Sector 111 Rear View Mirror £85-00
Goodridge Brake Line Kit £52-90
Courtenay Lightweight Flywheel £239-95
Carbontec front Vee £202-69
Invoice from Regal for Cool Running Thermostat, Fitting of alloy Rad, Powerflex Engine Mount, EDS iNtercooler Kit, DBILAS Flowmaster Air Intake, EDS Software, Plus Fitting All Above £2134-01
Eliseparts Upgraded Cooling Fans £77-15
Eliseparts Alloy Radiator £352-44
Flame beater “Carbon Fibre” Fire Extinguisher
£17-57
Plans M/S large Cambelt Service Feb 08 £894-33
Denso Iridium Park Plugs £40-00
Plans M/S Receipt March 08 Upper Wishbone bushes 18800mls & Setup £283-18
Regal Receipt including Hybrid VXR Turbo, EVOMS Diverter Valve, Coilpack, Fitting Of Exhaust, Adjustable Fuel Pressure Regulator, Samco Breather Hose, Dyno Run plus labour on the above, May 09, 22250mls £2359-81
Regal Receipt 80mm MAF, VXR Fuel Rails, software upgrade, Plus Labour july 09 23053mls £784-50
Regal Receipt Service With Vac Lines etc, March 10, 23871mls £304-64
Track V Road Receipt For Service plus all fluyids changed July 11 £728-39
Gaz Gold Pro Coilovers July 10 from Cliffie on VX Forum £550-00
Blackboots Chesham Fitting Shocks £82-25
Cornering Force Front and Rear ARB Setup plus corner weighting, Lower Spring Rates, Fit Uprated Hub Carrier Bolts, Dyno Dampers/Revalve/Adjust plus printouts £1233-75
New Coilpack August 11 £83-99
Brake Fluid Change Nov 11 Halfords racing Fluid as recommended on VX Forum and Cured All Brake Fade! £30-72
Forge Dump Valve £134.02
Barkes are 295mm Front Discs plus Alloy Bells & 1144 Pads all round.
In the Service book:
20/11/06 Stokesley Motors Main Dealer 9768mls
15/02/08 plans Motorsport (Cambelt) 18594mls
02/07/08 Sunray Motors 19872mls
06/05/09 Regal Autosport 22249mls
19/03/10 Regal Autosport 23871mls
07/07/10 Track V Road 27894mls
Timing Belt Due Feb 13 on time rather than mileage.
Service book doesn’t show the three oil and filter changes that I have carried out as a matter of care!
There are a other receipts for odds and sodds that I haven’t listed and as you can see this ais a well cared for VXT with over £14185-00 of receipts. On top of this are the Team Dynamics wheels and tyres (Good Tread).
Trevor 07939 887791
