Found Potential Car But No Real History.....your Thoughts Pls!
Posted 22 October 2012 - 01:19 PM
Posted 22 October 2012 - 01:31 PM
that is not correct, the two chains have a life span of ten years (or 100k whichever comes FIRST) so will need replacing due to ageThe engine has only covered just over 50k therefore is not needing a timing chain replacement
Edited by vocky, 22 October 2012 - 01:31 PM.
Posted 22 October 2012 - 01:38 PM
Posted 22 October 2012 - 01:59 PM
Just for the record, I believe that the TWO chains Vocky mentions are the timing chain and the balancer chain. Two separate kits are required. Also if you do buy it, you'd want to make sure that the timing chain kit used is the latest genuine GM version with the domed tensioner.
I'm sure he will correct me if I'm wrong.
R
Posted 22 October 2012 - 02:05 PM
Edited by vocky, 22 October 2012 - 02:06 PM.
Posted 22 October 2012 - 02:07 PM
Posted 22 October 2012 - 02:18 PM
Mechanically excellent: Red calipers, full MOT
Neither of those indicate mechanical excellence
And i don't think much of the ownwer's answeres either.
The engine has only covered just over 50k therefore is not needing a timing chain replacement Wrong
When these cars even have a minor claim they are put on the register , only due to body parts not being available from Vauxhall, even though you can get all of the panels from other suppliers, this car is on the register as 70% of all VXs are now Wrong (i bet it isn't even 20%)
Sorry no hardtop, they come up on Ebay fairly regulaly - £300-400 Wrong (more like 600)
No history (but all mots for last 3 years) and one key Says at the top, just serviced
The car is excellent mechanically, only needs bodywork sorting to make perfect, hence priced £2k below normal price of similar VX I see no evidence it is mechanically excellent, you have to take it apart a little and have a look
Posted 22 October 2012 - 02:21 PM
Thanks for clarifying that mate, useful info as I wasn't 100%.
Reg is covered in the add :-( will ask when I phone though.You got a link to the ad? Or stick the reg in here. 70% of VXs are not cat c/d for the record. The majority on here aren't. I would say that, although the cat rating would put me off personally, they are not that much of a big deal now. There are quite a few out there and they are becoming so easy to write off. Someone reversed into mine recently and it just scraped under the total loss bracket, but I couldn't have new parts fitted (other than the headlight) because that would have taken it over. Yet to see the work yet, but the beauty of GRP is that it can be patched up and in most cases ends up stronger than the original bit. Bodywork should be seen as a sacrificial part on these cars as none of it is structural. I would want to know exactly what damage was sustained and what was repaired/replaced.
On the question of history, as Vocky says you can knock a few hundred quid (think the chains alone are around £170 IIRC) off for getting the chains replaced as likely hood is the car is near, if not over 10 years old. In other news the lack of history is probably (and I am wildly guessing here) the fact that the insurer/scrap yard didn't bother getting it off the previous owner when the car was handed over after the total loss claim. The best thing you can do is look at the market, see if the seller has indeed sensibly priced it versus similar milage examples with similar history (cat rating does knock anywhere from £1500 - £3k off the price). Otherwise the lack of history isn't too much of an issue provided that you carefully check all the usual places (engine mounts, bushes, steering rack, dampers, etc etc), MOTs for the last 3 years will confirm the milage for the last three years is continuous, not prior to that. I would suggest a full HPI check on anything with an unknown or confused history.
Take a local member along with you to look at it for beer tokens. There are a few about Leeds who would be willing to help. Good luck with your search
Defo look to HPI this and keen to know what damage was done previously as if it's too bad think I'll move on for sure!
Sounds like even away from a stealer I'd be looking at £600+ish!?.....good info to know!!!Cam chain = £175, balancer/water pump chain = £140, so just the chains will be £315 + labour.
Main dealer will want about £1200 to supply and fit them
Pattern chain kits are designed for standard vectra/astra/zafira, I would not recommended them for a vx220
It's on at £5,300 so I'd say cheap really but suppose changing chains from info above pushes it to about £6k before we even begin.How cheap is cheap? That car would have to be very very cheap to make me jump at it. Very easy to rack up a large bill on these cars if it's not been loved and cared for.
There are so many well known cars about, why would you take the risk with an unknown car?
Posted 22 October 2012 - 02:25 PM
GBobM's car didnt go for much more than that and would be the sort of thing i'd be looking at.
EDIT : http://www.vx220.org...ed-cheap-price/
Sold now but gives you an idea of the competition
Edited by LazyDonkey, 22 October 2012 - 02:29 PM.
Posted 22 October 2012 - 02:33 PM
GBobM's car didnt go for muchmoreLESS than that and would be the sort of thing i'd be looking at.
£5300 is not bad if it all rings true, but I would check everything on it first before taking the jump.
Posted 22 October 2012 - 02:37 PM
http://www.gumtree.c...ery-item-full-2
If the whole car was red rather than just the calipers then it would have been worth more.
Posted 22 October 2012 - 02:39 PM
Posted 22 October 2012 - 02:46 PM
Thanks for that, helpful.
Ye that's the one.Just found it:
I'm not convinced but Gunnar ring the bloke later to get more info on previous damage etc as think that's key for me.
That's my guess :-)Turbo headlights on an NA. Mmmmmm front end smash.....
Posted 22 October 2012 - 02:47 PM
Posted 22 October 2012 - 03:21 PM
Posted 22 October 2012 - 03:29 PM
Posted 22 October 2012 - 03:41 PM
Posted 22 October 2012 - 04:12 PM
Posted 22 October 2012 - 04:58 PM
