Posted 24 October 2012 - 11:29 AM
Posted 24 October 2012 - 11:30 AM
Posted 24 October 2012 - 11:32 AM
Flat battery. When was the last time you used it?
Posted 24 October 2012 - 11:33 AM
Posted 24 October 2012 - 11:35 AM
Edited by NickB777, 24 October 2012 - 11:37 AM.
Posted 24 October 2012 - 11:43 AM
Posted 24 October 2012 - 12:24 PM
have you checked the voltage of the thing
I was having battery problems again but after removing the earthing points and filing them down to give a clean contact and wire brush on the body, she seems fine. Pain doing the one in the front though battery out job
Check if the connectors are on the terminals properly. If they are loose then it does the clicking thing too.
Also, it won't be charging properly if it's not got a good connection.
Posted 24 October 2012 - 12:29 PM
Posted 24 October 2012 - 12:33 PM
Edited by simsy, 24 October 2012 - 12:41 PM.
Posted 24 October 2012 - 12:43 PM
Posted 24 October 2012 - 12:44 PM
Posted 24 October 2012 - 12:45 PM
Posted 24 October 2012 - 12:51 PM
If your car doesnt have central locking then ignore this but if it does then this is worth a look.
I had the same problem! I tried differnet batteries, cleaned the terminals etc but it turned out to be the back up battery that opens the doors with the secret button that was draining my main battery, it was faulty, it had bulged sides and was really hot! You could feel the heat therough the clam from the outside. I would definitely check this first because it's probably the fault. To remove it just look in the boot on top of the nearside rear wheel arch, it's in a small plastic box, just unscrew the cover undo the terminals and rmove. very simple. they're about £15 to replace but i've just left mine out for now and my main battery has been perfect ever since!
HTH
Andy.
Posted 24 October 2012 - 12:58 PM
Posted 24 October 2012 - 01:01 PM
Only a trusted or calibrated volt meter can be relied upon to read to this accuracy. Most professional quality digital meters will.
Posted 24 October 2012 - 01:17 PM
Posted 24 October 2012 - 01:20 PM
Posted 24 October 2012 - 01:51 PM
If you have never had battery drain problems before I would defiantly check how tight the battery clamp connections are I had the same problem after fitting a new battery worked fine for a few days went work in the Vx jumped in to come home with a few mates around and you guessed it click bonnet up tighten the connection and away we go. The connections are crap also check it hasn't spun a little and shorting onto the tub as it is very close at best
Posted 24 October 2012 - 01:52 PM
Posted 24 October 2012 - 03:57 PM
