Is My Battery Dead Again?
#61
Posted 25 October 2012 - 07:10 PM
#62
Posted 25 October 2012 - 07:15 PM
#63
Posted 25 October 2012 - 07:52 PM
If you find anything shout up
Can't find anything on mine but without the cetek
It dies within a couple if weeks
Will do, thanks for all the help so far
I'm 90% sure its the ecu relays/fuses as they're fairly new.
#64
Posted 25 October 2012 - 08:04 PM
How do you do a parasitic draw test.....? Cheers, Paul
Pretty much as Chris said earlier in the thread, but this is the best video to show what to do
#65
Posted 25 October 2012 - 09:35 PM
Thanks - completely missed that!
#66
Posted 26 October 2012 - 09:51 AM
#67
Posted 26 October 2012 - 10:07 AM
#68
Posted 26 October 2012 - 10:37 AM
#69
Posted 26 October 2012 - 01:01 PM
Have you been back for your old battery
That one was well dead! AA bloke said it had 1.3v in it
#70
Posted 26 October 2012 - 01:03 PM
Your relay probably stole the other Vs
#71
Posted 26 October 2012 - 02:36 PM
#72
Posted 26 October 2012 - 02:48 PM
Well found!
BTW
Do parasistic current draw on the negative cable, its a bit safer.
I.e. you can not weld your spanner to the aluminium chassis and short the battery, bursting the battery case and spraying you with acid, or just blowing a hole in the aluminium....etc.... when you undo the negatuive.....
I have seen the result of a guy testing a starter motor on a battery he just took of charge and was still gassing off .
The base of the battery and the four corner sections were still clearly visible
A battery can be a very dangerous bit of kit
Good advice
#73
Posted 26 October 2012 - 03:01 PM
#74
Posted 26 October 2012 - 03:06 PM
#75
Posted 26 December 2012 - 12:34 PM
0.36 amps is quite a lot
around 4 watts i think
Bugger, thought so
Its a pig to disconnect at the alternator.
0.36 amp is not a lot and may well be normal.It would take a long time to flatten a battery .
Maybe someone knows the normal current drain if any,or try a search for it ,I am not sure sorry.
Google (mostly american people) say a normal about is 0.050amps is normal, mine seems a lot more than that. I may be a moron though and be reading decimals wrong
Thats easy done so,
So 0.36 is way high if correct, Fancy missing " the fuses " back to the drawing boardgood luck .
Thats why i should never be trusted with important things... Dont tell Wick this though, i replaced his battery for him a few weeks ago
Im quietly confident its one of the ECU relays/fuses as it didnt do this before the webcon conversion. Just my luck to get a dodgy relay
And there is me sat here with a new battery in the VX but it's dead on the driveway!!!
This thread hurts my head after the vino consumed yesterday over Xmas, might have to wait til the weekend lol!
#76
Posted 26 December 2012 - 03:54 PM
so which relay is this and where is it or even is there on on an NAjust a case of altering the permanent +12v feed for the brown relay to a switched +12v (from the grey relay feed)
