Dg Vx220 Standalone Package
119 replies to this topic
#101 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 December 2012 - 08:00 PM
I agree with letting the car warm up,I always do this before I take it out anyway :)
#102 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 December 2012 - 09:10 PM
I really fancy this with the DBW TB
#103 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 28 December 2012 - 11:47 PM
not sure tbh? Chris said it was about as good as he could get it, assume its probably more TB related than ECU? as said not a problem anyway as it's not a 'daily drive' and letting a high power engine idle for a few min to let the oil circulate and gently warm up is good practice IMHO thumbsup
I entirely disagree - I've always been led to believe idling is the worst situation a cold engine can be in. Happy to be corrected however...
Idle gives highest cam load. I'm unsure if oil protection is significantly reduced when cold at idle versus hot at high revs, but you cannot argue with the loading and corresponding wear on the valve train.
By it sitting idling temperature will take longer to come up than driving - throughout that time the engine will be running enriched fuelling to keep running. Coupled with an incomplete burn due to low temps and you are leaving deposits throughout the engine, on plugs and in the cat.
Just to add I only know of two setups where it needed a short idle time. A carb'd setup on DHLA 45s, where there was no enrichment/cold start choke setup. That needed 30 seconds at 10% throttle to stop it stalling, then a minute or two of idling to get some cylinder heat before you could drive properly. It was however a fairly tuned engine with a lot of valve overlap and cold plugs.
The second setup was a sprint/hillclimb. That ran very high compression on forged pistons. Due to material density the piston to bore clearance is apparently required to be greater than for cast pistons (IIRC 1.4 times normal). This setup was left to idle for a couple of minutes, I was told to get some heat into the pistons and allow the clearances to close up - if run up from dead cold it would puff some oil smoke, after 2 minutes ran spot on.
Edited by Boombang, 28 December 2012 - 11:54 PM.
#104 Bargi
Bargi
  • 4,483 posts
Posted 29 December 2012 - 08:41 AM
The cold mapping is something that seems to be hard to do, SC cars are the same and CS have been doing them for years
#105 allsteel
allsteel
  • 445 posts
  • Interests:Winning lottery tickets,scantily clad women,real ale poured with a head,modified cars,great guitar playing.
Posted 29 December 2012 - 10:00 AM
Yes, i might be up for that. What's the price on fly by throttle.
#106 NickB787
NickB787
  • 7,813 posts
Posted 29 December 2012 - 10:51 AM
Think that it's only available on N/A s/c cars
#107 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 08 February 2013 - 02:04 PM
http://www.vx220.org...ap-power-graph/
Most recent conversion completed
DG
#108 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 08 February 2013 - 02:15 PM
Good news Dunc.
#109 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 08 February 2013 - 02:18 PM
Thanks Mike, At least the terrible weather has had its uses :) DG
#110 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 25 November 2013 - 06:01 AM
Bit of an update on the standalone stuff
Further to all the great stuff this standalone adds to the vx220 the package now retains the full oem canbus so you can reset airbag / connect to ABS etc via obd port
Also running DBW retaining oem pedal fully along with the adjustable pedal option
In gear boost setting via abs filter box (small extra charge) x4 fiters required for ECU with TC option
And switchable map via switch
There was a £100 price increase across all of the ECU range this year but with further development and reduced labour time to install the total cost of install will actually be cheaper. I need to confirm cost to upgrade to the TC option and double check hardware costs and will update later today
DG
#111 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 25 November 2013 - 07:15 AM
Interesting timing. Will there be a cost to bring the "package" up to current spec or will it be done FOC as a recall? If there's a cost, how much?
#112 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 25 November 2013 - 08:08 AM
Well just about finished a big project and looking at what I may or may not do for 2014 Will give you a bell this week and catch up George sure we can sort something out if you feel its worth the work DG
#113 slindborg
Posted 25 November 2013 - 09:56 AM
a) its CAN*, b.) the VX has no CAN unless youve added it to the car
not nit picking (well ok point a was), but dont want people who dont know well enough to ge the wrong end of the stick .
#114 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 25 November 2013 - 10:55 AM
Fair cop slinborg. 5 days running with 4-5hrs sleep and 4am up with kids who have lurgy and crazy busy with work. Done me in. oem vx220 features via diag port retained for airbag, Abs etc. Vag wiring and other things in my head also has warped the details Been this tired is worse than posting drunk lol DG
#115 slindborg
Posted 25 November 2013 - 11:08 AM
no probs, was willing to be proven wrong on that but as said, didnt want people getting a bit excited that their ebay diag kit would suddenly do new stuff :lol:
#116 siztenboots
  • 26,613 posts
Posted 25 November 2013 - 11:17 AM
a) its CAN*, b.) the VX has no CAN unless youve added it to the car   not nit picking (well ok point a was), but dont want people who dont know well enough to ge the wrong end of the stick .
nit picking , but its ISO 14230 KWP2000 , on the K line wire. ISO 15765 CAN would be nice to have for fasting tooning
#117 slindborg
Posted 25 November 2013 - 11:45 AM
if someone drops the CCP stack into their software then it will be a breeze to do setup, then again most have got the USB interface sussed so there isnt a huge need to push CAN into the aftermarket world as yet. This should change as people are less and less happy with hacking the crap out of their cars to make them faster, but on the flip side all these 'remaps init' are keeping the OEM ECU to also remove the issues of getting 'round' CAN
#118 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 January 2014 - 09:47 AM
Bit of an update on the standalone stuff   Further to all the great stuff this standalone adds to the vx220 the package now retains the full oem canbus so you can reset airbag / connect to ABS etc via obd port   Also running DBW retaining oem pedal fully along with the adjustable pedal option   In gear boost setting via abs filter box (small extra charge) x4 fiters required for ECU with TC option   And switchable map via switch   There was a £100 price increase across all of the ECU range this year but with further development and reduced labour time to install the total cost of install will actually be cheaper. I need to confirm cost to upgrade to the TC option and double check hardware costs and will update later today   DG Just out of interest did you find out the total costs?
#119 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 31 January 2014 - 09:55 AM
I have but due to other commitments have not had time to put something clear together. I will try to get updated asap
Sorry for delay replying only just seen it
DG
#120 Bumblebee
Bumblebee
  • 7,592 posts
Posted 31 January 2014 - 10:40 AM
No probs DG Just gives me something to think about :)
