Edited by Јason, 30 October 2012 - 09:49 PM.
Engine Out... Tips Please..
Posted 30 October 2012 - 09:49 PM
Posted 30 October 2012 - 09:57 PM
Edited by Duncan VXR, 30 October 2012 - 09:57 PM.
Posted 30 October 2012 - 10:22 PM
Posted 30 October 2012 - 10:57 PM
Posted 30 October 2012 - 11:06 PM
Posted 30 October 2012 - 11:16 PM
Posted 30 October 2012 - 11:20 PM
Posted 30 October 2012 - 11:25 PM
Posted 31 October 2012 - 05:56 AM
Posted 31 October 2012 - 08:47 AM
Posted 31 October 2012 - 10:11 AM
Posted 31 October 2012 - 11:01 AM
Posted 31 October 2012 - 11:48 AM
Posted 31 October 2012 - 01:18 PM
Posted 31 October 2012 - 02:26 PM
Posted 31 October 2012 - 08:09 PM
Posted 31 October 2012 - 08:25 PM
that should have said TWO decent trolley jacks, one to hold the engine stable and the other to help lift the heavy gearboxif you have an engine hoist then removing the engine is much easier, but removing the gearbox is quicker because you don't need to touch the rear clam, however it's physically much harder and requires a decent trolley jack to balance the gearbox on.
Posted 01 November 2012 - 11:50 AM
Edited by VXed, 01 November 2012 - 11:50 AM.
Posted 10 November 2012 - 08:05 PM
having removed one or two z22se engines I would.....
disconnect battery (quite important !)
remove rear clam
drain coolant
drain engine oil
drain chargecooler system (sc only)
remove exhaust manifold
remove inlet system
remove fuel rail and injectors (cable tie fuel pipes out of the way)
remove starter motor
remove alternator + belt tensioner
remove crank pulley (very important if leaving gearbox in place)
remove coilpack (just to stop it getting damaged)
disconnect engine loom from engine (you don't need to remove it from the car)
remove oil cooler fitting from engine block (to avoid damage)
remove the special 'vx220 only' oilway blocking metal/spring thingy (it sits inside the oil filter housing, they are extremely hard to get - don't lose it)
remove lower oil pipe + fitting from block
disconnect / remove anything else which might get damaged or I've missed off the list
then connect an engine hoist to the engine using correct lifting straps (either straps under the engine or use the engine lifting brackets)
remove the offside engine mounting alloy bracket
remove the gearbox bellhousing bolts (two next to exhaust, two above gearbox, one above starter motor, two under engine)
then it's probably time to lift the engine out, it needs to come out (and go back in) by moving the front of the engine towards the bulkhead, you will need to lever the engine off the gearbox and then simply lift it up and out
http://www.vx220.org...ps/#entry957653
Edited by Јason, 10 November 2012 - 08:06 PM.
Posted 26 January 2013 - 04:30 PM
Also tagged with one or more of these keywords: N/A, 2.2, Z22SE, Engine, Replace, Remove, Removal
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 exhaust, manifold, z22se, na and 2 more... |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 new owner, 2.2, na |
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 2.4l, intake manifold, gm12587878 and 1 more... |
General Discussion →
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 z22se, dbilas, issue, turbo |
The Market Place →
Car Parts Wanted →
Water Ingress Engine Cover For NaStarted by Gizza3434 , 05 Oct 2019 engine, cover, water, ingress |
