Stand Alone Ecu For Supercharged Nas
72 replies to this topic
#21 slindborg
Posted 06 November 2012 - 04:26 PM
Pass, No idea what the radicals use.... usually motorcycle powered vehicles have used EFI stuff, but some are moving onto others.
#22 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 06 November 2012 - 04:40 PM
Is that price for conversion and mapping? Have to agree with others, 1 extra bonus is not been tied to any tuner of play yourself if desired DG
#23 Exmantaa
Posted 06 November 2012 - 04:42 PM
Think we've been this route before... You will need a proper crank trigger (std 2.2's 7-1 pattern is a bit poor for resolution) plus a cam trigger for any decent aftermarket ecu and with those fitted I simply stick with my LSJ ecu + HP Tuners. Gives me enough flexibility for my goals and a conversion is not too expensive. Lot's of info available for SC-ed ecotecs and with their scanner software it's not hard to tune... And OEM for the Ecotec engine. :sleep: (That's probably why Joe fitted it now. :happy: ) @Cliffie; fit a 58-2 crank triggerwheel and we can set you up for an LSJ ecu + HPTuners pretty cheap!
#24 siztenboots
Posted 06 November 2012 - 04:45 PM
did you buy hptuner credits just for that ecu , i forget their licensing model but iirc for a single model you could program more than one ecu serial number?
#25 techieboy
Posted 06 November 2012 - 04:51 PM
Exactly. :ninja:
#26 siztenboots
Posted 06 November 2012 - 04:55 PM
hptuners , single vehicle = 2 credits = $99 unlimited year/model = 6 credits = $299
#27 Exmantaa
Posted 06 November 2012 - 05:03 PM
The license system of HPTuners is the only frustrating thing, but still a lot cheaper compared to stand-alone:
You can license for a certain ecu ID#, so that particular ecu becomes free to program. Or you can unlock a complete model year (more credits), or years ($$) and then all ecu's from that model year are free for you.
But it will quite difficult to source several US ecu's all from the same model/year, so it's probably a lot easier to simply buy a cheap used LSJ ecu and use/buy a license for it. (with more ecu licenses you get "discount" on a model license)
On a sidenote; you can tune several different ecu's with HPTuners, so if you maybe fancy a corvette V8 engine in the future? Or more VX related; the 2.0 DI turbo LNF engine from the Opel GT maybe?? :ninja:
#28 Thealastair34
Thealastair34
  • 988 posts
Posted 06 November 2012 - 05:54 PM
at £1,500 its twice the price of say omex 600, i appriciate you will need afew sensors ontop but it seem a fair amount more just to be able to plug it straight in, unless there is something differnt about the 2.2 engine that the omex system couldnt run?
#29 slindborg
Posted 06 November 2012 - 05:59 PM
the electronic throttle body for a start.....
#30 FLD
Posted 06 November 2012 - 06:19 PM
Omex aren't the most accurate ECU's. I wouldn't use one.
#31 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 06 November 2012 - 06:39 PM
Is the general consensus that the GEMS unit is OK and as long as it remains "owner" mappable it would be a good thing?
#32 Exmantaa
Posted 06 November 2012 - 08:40 PM
Will also depend on what else is needed to make this run. The std Z22SE's ecu is pretty awkward with the 7-1 trigger and the compression sense ignition module. (computes cam phasing together with the ecu) If a different crank sensor is needed plus a new cam sensor (for sequential fuelling), a different/modded engine loom will be necessary. It all adds up... :sleep:
#33 slindborg
Posted 06 November 2012 - 08:45 PM
Ad if modding the harness, you then step into the realm of sodding off the plug and play with the oe plugs trick and doing it the 'traditional' way as it will be much cheaper/easier.
#34 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 06 November 2012 - 09:03 PM
If I pay for this I want an unlocked ecu with software
Because you know how to map a car Nick?
No Mike I don't know how to map a car, wouldn't mind learning something about it though, why I wanted it like this is because I plan to take the car with me to Aussie and I want something which can be accessed for future mapping by someone there not just here in the uk.
Edited by NickB777, 06 November 2012 - 09:03 PM.
#35 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 06 November 2012 - 09:25 PM
Makes sense.
I can only ask the question but I am not pushing this development if there is no market for it.
#36 Thealastair34
Thealastair34
  • 988 posts
Posted 06 November 2012 - 10:32 PM
for what reason?
#37 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 06 November 2012 - 10:38 PM
Please don't shoot me down in flames, but if I was going stand alone I would want a traction control system. I know "learn how to drive blah blah blah" but with syvecs and others this is an option. I would also like to be able to have a few maps I can apply- tune it down to 200 if I wanted and have a map for full power when I want. Drag and drop maps would mean I could let others drive it and enjoy a little of the fun. All for seeing the car mapped properly though.
#38 slindborg
Posted 06 November 2012 - 10:57 PM
Makes sense.
I can see the pros of the product, but at the same time it is likely to have a lower uptake than that of the webCON throttle body kit... Reason is cost, 90% of modded z22 engines will cope fine enough with the calibration that courtenays can achieve, the other 10% might not want to spend half a supercharger cost just to eek some more go from it.
Maybe ditch the plug and play model and look at a more generic one that you might be able to sell in higher volumes and suit more of the VX modders as it'll be more accessible and have better reasoning for the purchase.
#39 siztenboots
Posted 07 November 2012 - 08:34 AM
can't beat the trionic stuff for value for money
#40 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 07 November 2012 - 08:37 AM
Makes sense.
Sage words Stu. I won't pursue it then.
