Hid Kit 35W Or 55W With Fly Eye Film?
#41
Posted 07 January 2013 - 07:41 PM
#42
Posted 07 January 2013 - 07:53 PM
Could you post a picture of your lights so I know what they look like with the film on . I may be doing the same.
As for the hids either are ok, personally I'd go for the uk ones
Hi Mate.
Sorry for the delay. Here are the pics you requested. Contrary to comments, I think Fly Eye is a great way of covering crappy lenses & hiding condensation. These shots of Fly Eye at dusk (with HID fitted). I will snap a few in the daylight (when I get a chance) so you can see how the film gives lenses a "solid(ish) black" appearance when headlights off. Cheers - Ben.
http://dl.dropbox.co...541695/BJVX.jpg
PS: Fly Eye is best fitted with headlight unit out (so you can "wrap" round the edges). Clean unit with panel wash first. Apply (cold) to front of lens (leaving plenty of "overhang" to wrap round sides).... heat overhang with a hairdryer / low powered hot air gun... stretch round sides for seamless adhesion... trim off excess. Simple!
#43
Posted 07 January 2013 - 09:47 PM
#44
Posted 07 January 2013 - 11:19 PM
#45
Posted 07 January 2013 - 11:27 PM
Watch going to HID on the 'full' beam tho, I did that a few years ago and hated it, you lost the ability to 'flash' other drivers as the ballasts need to warm up, and whilst night driving they fire up and then when traffic comes the other way you switch them off and then get the same delay when you go back on beam again.
Very good for the dipped & even H4 fog lights but not the main beam IMHO
#46
Posted 07 January 2013 - 11:44 PM
#47
Posted 08 January 2013 - 05:08 PM
I'm now interested to know peoples thoughts on H3's:
1. Is there a half decent 600k LED H3 replacement or is a THIRD set of HiD's & ballast the best way forward?
2. Can I put in HiD 600k bulb or Halfords look-a-like's requiring no ballast without killing the loom / fuse box (as I'm hesitant of having 3 sets of ballast strapped on!)?
3. What is best method of accessing H3's? (a) Reaching through with headlamp units out (
As always cheers for all your help & advise - Ben.
PS: Simba. After HiD warm up tests I a reconsidering H7's (they take an eternity to reach temp).... Will do thorough country lane tests (with HiD H7's & LED H1's) before committing. Thanks for wise words!
#48
Posted 08 January 2013 - 07:57 PM
Edited by turbobob, 08 January 2013 - 07:59 PM.
#49
Posted 08 January 2013 - 11:36 PM
I'm confused. Where is the h3 bulb?
And personally I wouldn't run hids in the main beam. Its actually the bulb that gets up to temp. The gas in tthe bulb turns into plasma. The plasma conducts electricity making it more active and less resistance. Lower resistansemce means more current flow and even more active etc. This would result in the bulb popping. The ballast is there to control the power / current flow.
As for overloading with ballasts. It doesn't matter how many you have. Its the power consumption that matters. Dipped and main beam have 55w bulbs fitted as standard. So the wiring is just capable of taking that current. Fitting a 35 or 55w hid kit is therefore fine.
Edit I would just fit something like an osram nightbreaker for the main beam as the are bright enough and instant.
Thanks Bob. Worthy comments. H3 spotlights? At least that's what I've been lead to believe. Any tips on getting at spots? Ben.
#50
Posted 09 January 2013 - 01:24 PM
#51
Posted 10 January 2013 - 02:12 AM
Spotlights? Are you talking about the front fog lights?
Yes.
Also tagged with one or more of these keywords: HID, Fly Eye, Lens Burn
General Discussion →
VX220 Discussion →
Hid Fog Lamp Mod > Switches & Wiring Advice Req.Started by Benzola , 18 Sep 2016 ![]() |
VX220 Discussion →
Which Bulb And Which Hid Conversion KitStarted by MJ101 , 31 Oct 2015 ![]() |
Other Models & Brands →
Christmas Present For The Better HalfStarted by james.a , 15 Dec 2012 ![]() |
