American Fridge Freezer Plumbed Or Non Plumbed
Posted 13 November 2012 - 10:15 PM
Posted 13 November 2012 - 10:21 PM
Posted 13 November 2012 - 10:45 PM
We moved into our current place just over a year ago and did a deal to buy the plumbed in American style fridge freezer off the former owner. Wouldn't be without it now. Its even got a small hatch in the front of the fridge to get easy access to milk etc without opening the door.
Edited by Wolfstone, 13 November 2012 - 10:50 PM.
Posted 14 November 2012 - 12:12 AM
Posted 14 November 2012 - 07:16 AM
The advantage of the plumbed in is iced water on tap and ice making system
We have a huge American fridge freezer which has instant ice and water but this is not plumbed. So much easier than plumbing in. The make is LG. recommend it to anyone.
Posted 14 November 2012 - 08:24 AM
Edited by westie, 14 November 2012 - 08:29 AM.
Posted 14 November 2012 - 10:23 AM
I went for a month or two without plumbing it as I couldn't be arsed but got home from work one day and decided to plumb it all in. Took all of 15mins. Shut the water off, using a 15mm pipe slice cut the pipe and fitted a push fit hep T. Ran 3m of Plastic hep pipe to the back of the fridge freezer, stuck a plastic hep washing machine shut off valve on the end and attached a 3/4" BSP to 1/4 plastic pipe on the end connected it all up job was a goodun. use it all the time now.
Just found this on ebay which should make your life easier http://compare.ebay....ype=pla&crdt=0#
Good luck Paul
Gareth
Posted 14 November 2012 - 11:52 AM
Posted 14 November 2012 - 12:17 PM
I move on 23rd Nov.
No help on the fridge freezer front I'm afraid, but we also move on the 23 Nov (then hopefully the headache will be over — booked a track day for the Monday as a little treat
Posted 14 November 2012 - 02:13 PM
Posted 14 November 2012 - 05:24 PM
I hear ya techie, normally that is the case. But the Samsung RSG5UCRS has 637 litres of space as it uses a super thin insulation and has a clever position for the ice maker (plus you can buy a version that doesn't have the ice bit so you get even more space). That's why I went for that model. It rocks and I love it, one of the best things in our kitchen.Can't understand the craze with these abominations. They're usually tiny and impractical inside, in comparison to their external size and force you to design your entire kitchen around accommodating the bloody things. You get twice the storage for <50% more wall space by having a dedicated fridge and dedicated freezer.
Posted 14 November 2012 - 07:16 PM
Posted 14 November 2012 - 07:18 PM
