Vacuum Layout / Schematic?
11 replies to this topic
#1 RalphyBMW
RalphyBMW
  • 764 posts
Posted 25 November 2012 - 09:33 PM
I want to know more about the vacuum system, boost control valves, what they do, and what is connected to what, etc. Does anyone have any kind of schematic? Thanks!
#2 Ormes
Ormes
  • 4,612 posts
Posted 25 November 2012 - 10:06 PM
Sorry, I have requested a schematic before and there isn't one. The end points are... 2 x solenoids Actuator Turbo Recirc valve Intake manifold FPR Vacuum box (probably others I have forgotten) You can check most of the tubing by taking the trays off, jacking and dragging yourself under, but easiest to check the boost solenoid/actuator/turbo from above by removing the intake pipe.
Edited by Ormes, 25 November 2012 - 10:07 PM.
#3 RalphyBMW
RalphyBMW
  • 764 posts
Posted 25 November 2012 - 10:08 PM
No prob, thank you!
#4 Ormes
Ormes
  • 4,612 posts
Posted 25 November 2012 - 10:14 PM
http://www.astraowne...ad.php?t=290382
#5 RalphyBMW
RalphyBMW
  • 764 posts
Posted 25 November 2012 - 10:18 PM
Fantastic, thank you!
#6 Nev
Posted 26 November 2012 - 09:58 AM
I understand it all, but the diagram is in my head.
#7 siztenboots
  • 26,611 posts
Posted 26 November 2012 - 11:35 AM
recirc is vacuum operated , waste gate is boost operated
#8 Nev
Posted 26 November 2012 - 12:27 PM
Does anyone know if the recirc is opened by the ECU/vacuum box solonoid just when the clutch is pressed in (for any gear) or is it gear depenedant ?
#9 Ormes
Ormes
  • 4,612 posts
Posted 27 November 2012 - 08:25 PM
My understanding is fairly limited but I thought that the vacuum in the intake manifold combined with boost against the diaphram opened the recirc whenever closing the throttle butterfly? I had assumed that the ECU uses the vacuum box (via the solenoid) to feed vacuum to the recirc when there is no vacuum from manifold (butterfly open). I was under the impression that this "overiride" is used when coming off the throttle (to part throttle?), to keep the turbo spinning? I may be out of my depth here :blush:
#10 Nev
Posted 27 November 2012 - 10:19 PM
I think you are right Alex, but I was wondering if this happens in all gears or just 1,2,3rd for example.
#11 siztenboots
  • 26,611 posts
Posted 28 November 2012 - 08:23 AM
yes, to improve driveability when coming off the throttle or clutch active the ecu opens the recirc (using vacuum source A or B ) to keep the turbo rpms high ready for the next use, ie. to stop the compressor wheel stalling working against a closed throttle.
primary vacuum source A is the intake manifold
reserve vacuum source B is the vacuum storage box under the IM.
#12 Ormes
Ormes
  • 4,612 posts
Posted 28 November 2012 - 06:54 PM
Cheers Nev/Sizten... It's nice to know that I am along the right lines :)
Edited by Ormes, 28 November 2012 - 06:55 PM.
