Brake Caliper Refurb
Posted 29 November 2012 - 04:45 PM
Posted 29 November 2012 - 04:53 PM
Posted 29 November 2012 - 04:57 PM
I gave up trying to find anyone after the companies I did contact said "no". Ended up buying a brand new pair of rears from Robin on here at a knockdown price.
I think I might buy a refurb kit and have a go at it...... I understand its not the easiest of jobs though!
Edited by FLD, 29 November 2012 - 05:08 PM.
Posted 29 November 2012 - 06:17 PM
http://www.bgdevelopments.co.uk/
They are in Bromsgrove. 01527 873716.
Posted 30 November 2012 - 08:50 AM
Posted 30 November 2012 - 11:17 AM
Same here - it wasn't much more expensive than having them rebuilt.
Posted 07 December 2012 - 10:26 AM
Posted 12 August 2013 - 10:28 AM
Has anyone had any luck in finding a company that will refurb the calipers properly?
Also want mine powdercoating in Black or Grey
Posted 12 August 2013 - 12:25 PM
I cant help with a company that will do them properly but I have had some trouble with the company that refurbed mine. I used these guys:
http://www.brake-cal...ml#.UgjT1dLVDTo
I had an issue with both of them and seemed to have been rebuilt incorrectly. Initially the finish and service was great but ultimately I had a refund for the work which took months to recover. I would strongly suggest they are avoided.
Posted 12 August 2013 - 12:32 PM
Posted 12 August 2013 - 01:01 PM
Why don't you have a go yourself? That's what I'm doing.
It doesn't seem too difficult http://wiki.seloc.or..._Brembo_Caliper
Posted 12 August 2013 - 01:18 PM
Posted 12 August 2013 - 01:29 PM
I was just planing on getting a couple of these http://www.elisepart...urbishment-kit/
No pistons included, but there's no real need to change that.
Posted 12 August 2013 - 07:21 PM
Because half the parts aren't available and I've never read of anyone having any success trying.
Done several.. It's not hard, *but* you have to be careful and be prepared to skip some parts if they are too stuck.
There's one big problem and that's the grub screw inside the casing. This tends to rust solid into the housing and is also an oddball (4.5mm) size. It can be impossible to remove this.
In itself this does not have to be a showstopper as it means you can still refurbish most of the caliper. The only thing you can NOT replace in this case is the O-ring that seals the handbrake shaft through the housing, but luckily this is often not a problem area so can be left in place. All the other seals can still be replaced.
The second potential problem point is the small screw with O-ring groove that's inside/under the piston.
But the good news is that it does not have to be removed as the original docs mention. These screws are made from a very soft metal and are secured with a strong threadlock, so they tend to snap/shear if you try to undo them.
The part of the handbrake mechanism that fits inside the piston can still be removed from the bore if you use a bent screwdriver to gently lever the snapring inside the bore out so the whole mechanism comes out as 1 piece and can be refitted to the piston after renewing the seals.
Refitment is a little more tricky if the lower grub screw could not be removed, but usually the standard method of pressure and 'screwing in' the piston does bring the gap in the foot of the handbrake mechanism over the brub screw and it seats in place and the snapring then re-expands in the groove inside the bore.
All done
All in all it's more difficult than the fronts, which are very easy (but they are prone to corrosion problems on the screw threads for bleed points and hose attachment), but still not that difficult.
Posted 12 August 2013 - 07:26 PM
Had my fronts refurbed and powdercoated by Hofmanns and they've been spot on for the three years since. As above, gave up trying to find someone prepared to tackle the rears and bought a new pair of rear calipers from Robin.
Did the refurb make a difference? I'm swapping out my rears as part of my suspension refresh but want to know if it's worth doing anything with the fronts. I haven't ever been completely happy with the brakes and suspect 84k miles hasn't made them any better
Posted 12 August 2013 - 09:26 PM
I don't think there was anything wrong mechanically to start with, just showing the effects of time. Seals were torn and the pistons had a bit of corrosion on but no negative effects. The refurb didn't have any night and day effect, at least not that I noticed any difference over and above the change of pads at the same time. Always had bigger issues with the rears and the handbrake mechanism not always backing off enough when released and causing the offside rear to occasionally drag. I've still got a couple of pairs of rears in the garage and a couple of Elise-Parts refurb kits, maybe I'll give them a try one day but I'd really like new pistons for them as well.Did the refurb make a difference?
Posted 12 August 2013 - 09:37 PM
Posted 12 August 2013 - 09:43 PM
