Central Locking Retro Fit Tubby
Posted 02 December 2012 - 03:43 AM
I'm looking to retro-fit the factory central locking option to the tubby I'm buying from Mark. Anyone know of where I can lay my hands on the components?
Also, as a noob and rank amateur, this guide looks like it might be quite helpful but I can't see any of the linked photos. Any other guides I'm missing which do have something to follow?
Do the alarm units in the tubbies all have outputs for central locking which are essentially plug-n-play?
Thanks
Dunk
Posted 02 December 2012 - 06:30 PM
Posted 02 December 2012 - 06:43 PM
http://www.speedster...stem/index.html
Its parts 22 and 23 on here that I might have access to.
Edited by Wolfstone, 02 December 2012 - 07:04 PM.
Posted 03 December 2012 - 12:16 AM
Posted 03 December 2012 - 10:07 AM
Posted 03 December 2012 - 10:20 AM
Posted 03 December 2012 - 10:26 AM
Posted 03 December 2012 - 10:28 AM
Posted 03 December 2012 - 10:41 AM
I'd like to give Dunk first refusal Ray. I've PM'd him. Qazax is then next in line. I'm nothing if not fair. :)/>
And your fairness is something no one would ever doubt
Posted 03 December 2012 - 12:19 PM
Hope you'll understand that its only fair to give Dunk first refusal as its his thread.
Yup, fair's fair. Also a rough idea of how long it would take to fit would be appreciated too. With all the work that is required on my car, I am 90% interested in just hearing how much it would be, and 10% likely to actually buy one, but if it is not too much and wouldn't take hours to fit then it will get serious consideration. Once I have some new shocks, and fixed whatever is up with the turbo that is...
Posted 03 December 2012 - 12:39 PM
Posted 04 December 2012 - 05:37 PM
Posted 05 December 2012 - 10:17 AM
I didn't get the module etc.. from Vauxhall too expensive, my kit cost £19.95 as I wanted two masters but actually no need for two masters on the vx and wouldn't do two masters if I was installing in again so this £14.95 kit will do the trick http://www.rclick.co...products_id=267
I have been running this CL kit now for 3 years with no problems, I have now also installed the turbo CL pins on the doors and a turbo CL switch on the steering column so all looks 100% standard. As a just incase thing (although never needed it) I did install a switch to cut the power to the CL module, this way if it did ever pay up I could disable it and go back to manual locking.
Posted 05 December 2012 - 05:14 PM
Posted 05 December 2012 - 10:31 PM
I don't know why the photos of gone, I have had couple of PM's regarding this lately, here is a link to the photos http://s812.beta.pho...Central Locking
I didn't get the module etc.. from Vauxhall too expensive, my kit cost £19.95 as I wanted two masters but actually no need for two masters on the vx and wouldn't do two masters if I was installing in again so this £14.95 kit will do the trick http://www.rclick.co...#38;products_id=267
Thanks!
Posted 06 December 2012 - 12:19 AM
Thanks for sending the link to the pictures over recently. Just ordered the CL kit so will use the pics to help installation. Could you message me how you did the failsafe switch and where you mounted it, as that might be a good idea - just in case as you said.
Thanks
Posted 06 December 2012 - 07:49 AM
Thanks
I mounted the switch on the metal beam under the dash (not sure what it is called) near the steering column, but you can mount it anywhere I just did it there so you can't see it and you just need to reach under to switch it. Basically just put the switch inline with the constant power feed to the CL module, so when you flick the switch all power is disconnect to the module.
Posted 07 December 2012 - 02:16 AM
Posted 07 December 2012 - 09:25 AM
Thanks Dan. I wasn't sure whether you mounted a switch outside of the passenger compartment so that if the central locking didn't work you could cut the power from outside and still use the key easily.
Once CL is fitted and it use, using the key in the door has no effect, so if you have locked the car via CL then you can't unlock the car via the key in the door (this is the same as a Turbo with standard CL)
Posted 07 December 2012 - 01:26 PM
Also tagged with one or more of these keywords: central, locking, breaking, oem, factory, retro, retro fit, tubby, central locking
The Market Place →
Car Parts For Sale →
Black Soft TopStarted by navx , 02 Sep 2018 ![]() |
The Market Place →
Car Parts Wanted →
Lockingbolt On BonnetStarted by nielvredeveldt , 18 Apr 2018 ![]() |
General Discussion →
VX220 Discussion →
Couple Of Things!Started by DX220 , 24 Apr 2017 ![]() |
The Market Place →
Oem Wheels On EbayStarted by ee601 , 21 Aug 2016 ![]() |
VX220 Discussion →
Part Of Sills Required Where Rear Clam AttachesStarted by dylan390 , 18 Mar 2015 ![]() |
