Central Locking Retro Fit Tubby
central locking breaking oem factory retro retro fit tubby central locking
26 replies to this topic
#21 d4nnyk
d4nnyk
  • 769 posts
Posted 07 December 2012 - 01:58 PM
As an idiots guide. How much roughly would it cost to retrofit? its never bothered me not having it befor but if its reasonable I may be tempted.
Roughly £20-£30 if you add connectors, cut off switch and a bit of cable.
EDIT: It will cost more if you wish to add OEM steering column switch and door pins
Edited by d4nnyk, 07 December 2012 - 02:11 PM.
#22 RalphyBMW
RalphyBMW
  • 764 posts
Posted 07 December 2012 - 02:29 PM
Most of the c/l kits I have seen don't appear to have the boots that protect the wiring between the door and the car, any idea what these are called?
#23 d4nnyk
d4nnyk
  • 769 posts
Posted 07 December 2012 - 02:40 PM
No kits don't, I used some grommets in the holes and some corrigated wire sleeve (not sure what it is called) we had it in our parts department, here is a photo:
#24 RalphyBMW
RalphyBMW
  • 764 posts
Posted 07 December 2012 - 03:02 PM
How did you go about drilling the holes, did the doors need to come off?
#25 d4nnyk
d4nnyk
  • 769 posts
Posted 07 December 2012 - 03:05 PM
No need to take the doors off, just use a drill, it is fibre glass so real easy. Just make a small hole then gradually make it bigger
EDIT: with the gomment I cut the lip of the side to can't see off as the fibre glass is thicker than the gomment and just secured it with a little bit of sikaflex, 3 years later still in place.
Edited by d4nnyk, 07 December 2012 - 03:07 PM.
#26 RalphyBMW
RalphyBMW
  • 764 posts
Posted 07 December 2012 - 03:06 PM
Thanks
#27 Dunk
Dunk
  • 1,224 posts
  • Interests:WLTM reliable, quiet, tidy one for LTR.
Posted 07 December 2012 - 03:55 PM
http://www.vx220.org...60#entry1459022 Apologies for the delays - I'm the culprit & it means I no longer need the kit. Not sure who's next on Ken's list...
Also tagged with one or more of these keywords: central, locking, breaking, oem, factory, retro, retro fit, tubby, central locking
