So i decided since I was off today and I had a spare afternoon I should do some work on the shed.
The front brakes were the first to be tackled.
Bit of a ball ache getting a lot of the bolts off and the disc itself was pretty stuck. That's when I found that the mazda discs have a threaded hole through the disc. I thought it was for a retaining screw that was missing, but then it all became clear.
Bolt through the hole and screw breaks the seal and the disc pops off.
A lot easier once I found out that one.
So I put on the new disc and try to fit the caliper. hmmmmm, wont fit.
I hold the old disc up to the new one and guess what? The new ones are bigger. Feck!
Found out that even though I put in my registration on the eurocarparts site, there were two different sizes.
Popped along and got the discs swapped over and by that point it was getting dark and cold. Typical!
So I managed to fit the discs, after wrestling with the rear pads. For some reason on both sides, the inner pads were really stiff and took a hammer to seat them right. The outer ones just popped in as they should.
So now I have some nice shiny new front discs fitted.
Sorry about the sh*t pic, but it was dark and the flash on my phone camera is sh*t.
Took it out and although it was very spongy to start with the pedal was starting to stiffen up. Managed to lock the fronts at 30mph, so can't be too bad. Will do the rears and the fluid and some point soon.
