Headlights Wont Turn On...
hids lights cut out
49 replies to this topic
#41 D3YMO
D3YMO
    Scammer
  • 1,554 posts
  • Interests:Cars, Gym, Basketball, Football, LFC, Usual Stuff...
Posted 01 March 2013 - 11:23 AM
i sprayed it with wd40 yesterday which seemed to make it work (in conjunection with the other things)...is this advisable to use?
Edited by D3YMO, 01 March 2013 - 11:23 AM.
#42 Harry Hornet
Harry Hornet
  • 4,973 posts
Posted 01 March 2013 - 11:25 AM
makes sense...the lights did flicker when turning right on some bends before they went off
when you say a break in one of the wires...do you mean just the headlight wires, or could it be any of the wires causing the trip?
(appreciate you help up to now fezzasus)
I know a few people have had issues with wires corroding at the fuse box.
:yeahthat: ..mine were corroded at front, under wheel arch..flickered, went off, flickered went off, then stayed off, especially over bumps...changed wiring all ok..(not easy or cheap though) :(
#43 fezzasus
WD40 is okay, it's a white oil so means it's light and has got good capillary action to get into all the gaps, however it doesn't have anything in it to stop further corrosion, where as ACF50 has a corrosion inhibitor in it - you can get a can of it for about a tenner on ebay.
#44 D3YMO
D3YMO
    Scammer
  • 1,554 posts
Posted 01 March 2013 - 11:27 AM
cool, ill invest in that too i definately dont want to go down the change the whole front harness route
#45 techieboy
Posted 01 March 2013 - 11:48 AM
I might spray the whole thing with ACF50 now just to make sure of it.
I've done just that, to all exposed connectors (especially the fusebox and relay bases) annually for the last 4 years.
#46 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 01 March 2013 - 12:50 PM
Whoa. A bit of caution required. If you have a break / intermittent contact then a spark will ignite the wd40. Be very sure of where you are spraying it. As above try giving the loom a bit of a tug / shake around the fuse box with the lights on to see if it does cause a flickering.
#47 D3YMO
D3YMO
    Scammer
  • 1,554 posts
Posted 01 March 2013 - 12:55 PM
thining about it, it did yesterday briefly...
then after messing about a little more and moving the car they came to life
#48 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 01 March 2013 - 12:56 PM
that's kind of a good sign. It gives you a possible indication of where the fault may be. Focus on that area and try to close down the issue. Chances are the more you follow it, the more likely you will see something that is causing it.
#49 D3YMO
D3YMO
    Scammer
  • 1,554 posts
Posted 01 March 2013 - 01:01 PM
ill report back later today
#50 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 01 March 2013 - 01:10 PM
Ok, I'll be interested to see what you find. And will help as much as I can.
Also tagged with one or more of these keywords: hids, lights, cut, out
