Bulkhead Build Getting Ready For My Coupe Parts
243 replies to this topic
#1 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 08:08 PM
I wanted to change all my fuel pipes etc so I thought I would do my bulkhead ready for when my coupe parts are done ,so out came the grinder and jigsaw .
And rear window
And then alli to form the bulkhead
Lots more room to bolt my Harrop up
Getting there :-)
I am going to cover bulkhead in gold heat reflector and build an air box for my new filter design
Edited by leevx2.2, 04 January 2013 - 08:10 PM.
#2 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 08:21 PM
End result should be like this
#3 CocoPops
CocoPops
  • 17,181 posts
Posted 04 January 2013 - 08:24 PM
Brave man! :unsure:
#4 fezzasus
Looks good Lee, is it removable or bonded as well as bolted?
#5 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 08:27 PM
Not to sure was going to bonde and bolt but is very secure and could be handy to leave removable .
#6 fezzasus
Posted 04 January 2013 - 08:33 PM
Some foil tape around the edge might be a good compromise. I've got about 10 of sound insulation (acoustic thinsulate - felt type stuff for the interior side of the bulk head) if you want me to drop some over next time i'm in MK.
#7 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 08:42 PM
That would be great if you could mate and you can pick up charger as well ;-)
#8 The Batman
Posted 04 January 2013 - 08:43 PM
drop enough off for 2 please ;)
#9 fezzasus
Posted 04 January 2013 - 08:46 PM
No problem, probably this weekend or the one after
#10 The Batman
Posted 04 January 2013 - 08:47 PM
love you long time!
#11 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 04 January 2013 - 08:53 PM
Hope it all works out for you. Looks very technical to me!
#12 Hark
Hark
  • 3,443 posts
Posted 04 January 2013 - 09:17 PM
Bloody hell that's brave, fair play.
#13 Nev
Blimey, thats a big old hole! Id deffo keep the pannel removable, really helps on my car for access to the other side of the engine IMO. Not sure you need to spend money on gold reflective stuff TBH, it's not like you have a hot turbo lurking near there! That airbox design looks ace, so long as enough air can get in though that little entrance slit. I did some calcs on my engine and my car consumes a room full of air 10' x 9' x 9' every minute, which is mind boggling. Yours will presumably want approx 3/4 of that, which is still a LOT of air. Good luck.
#14 vocky
Posted 04 January 2013 - 09:39 PM
you should shorten the coolant return hose (like on the throttle bodies cars) :sleep:
#15 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 04 January 2013 - 10:01 PM
No half measures there Lee! Fair play to you. Looks ace thumbsup
#16 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 10:18 PM
you should shorten the coolant return hose (like on the throttle bodies cars) :sleep:/>
Do you no what the thread size it is Neil or have you got a spare Saab adapter ;-)
Edited by leevx2.2, 04 January 2013 - 10:18 PM.
#17 The Batman
Posted 04 January 2013 - 10:20 PM
get the proper saab pipe lee its only £20 odd quid!
#18 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 January 2013 - 10:27 PM
You got part number Joe need pipe and adapter for head
#19 The Batman
Posted 04 January 2013 - 10:29 PM
cliffie does, there is a thread somewhere
#20 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 04 January 2013 - 10:46 PM
Looking good mate but i wouldn't have the balls to go that far, cutting the hole for the harrop is all i need. How much weight do you reckon you have lost with the window, roll bar, head pads etc etc all removed then the coupe back fitted, it must be quite a good saving? You have now lost all advisability from the rear, are you going to fit revers cameras?
