Honda K24 Powered Speedster
984 replies to this topic
#1 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 January 2013 - 09:32 AM
Hi
Here is my first project thread.
Now after that the son is just over 2 years and I'm done after 3 years with the interior renovation of the house
it starts to be time for my my car again.
I bought the car in spring 2011 and imported it to Sweden, but because I didn´t have so much time then (house renovation)
I almost didn´t drive it in summer 2011.
Last summer, the car has gone a few thousend miles. The car was completely original when I bought it.
The car
Before I took the car into the garage I had to repaint the garage to get some more light.
Old engine sold
147hk eco tech engine, among the most boring engine I´ve ever driven
Now it looks like this
Because this is going into the car.
To avoid the engine to be constipated so I thought I get help from this.
Unfortunately, it needs to be shorter, it would stick out behind the body if it is not cut short. Anyone have any idea? My idea is to put a 90deg 2.5 " bend between the collector and megaphonen. Or should also the bend be a cone?
New steering wheel, 10mm bigger the OEM.
New mirrors
Track wheels, not very nice looking, but The will get some new paint and be widend
Street wheels will also be painted black.
Since my garage is so small, I have to take the help of my hobby room, unfortunately it is just as small.
A planned expansion of the garage will ¨come first in 2014
The engine is a K24a4 with ERL sleeves.
Sleeves adjusted for Wiseco pistons that I bought that I think will give CR 10.5.
New rods, new oil pump, EP3 cams.
EP3 intake at first and K24a2 head.
I also bought a RSX wiring harness so I can drive broadband lambda directly.
The plans for this car is to get a nice track car, to drive rear wheel drive.
Obviously, it should be able to drive on the street so I can go and buy ice cream in summer time.
Further plans for the summer, removal of the suspension, remove rust and add some painted,
replacing the bushes as well as new shock absorbers.
Conversion from right-to left-hand drive.
Saab 9-5 aero brake discs at the front with new brake pads.
And some other stuff.
Regards, Per
#2 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 05 January 2013 - 09:35 AM
Interesting project you have there. Nice to see the end results. Good luck.
#3 OneYet
OneYet
  • 1,355 posts
Posted 05 January 2013 - 10:04 AM
Good luck! This thread will be followed.
#4 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 05 January 2013 - 10:07 AM
Interesting project thumbsup what are the track wheels?
#5 CocoPops
CocoPops
  • 17,182 posts
Posted 05 January 2013 - 10:09 AM
Interesting engine choice. What power is expected?
#6 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 January 2013 - 10:10 AM
Meaning? Brand or size? They are 16" *7
Brand I have to check.
#7 vocky
Posted 05 January 2013 - 12:49 PM
you need to make your exhaust similar to this
#8 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 January 2013 - 03:05 PM
This intake manifold I have isn´t the best so with this intake manifold I will have about 230whp with a better intake manifold about 240 whp NA.
Also piston chosen with CR 10.5 is very low since, I consider Supercharging in a year or so.
#9 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,861 posts
  • Interests:Big baps.
Posted 06 January 2013 - 10:37 AM
Given that you can get 240bhp very easily from a turbo or an SC, certainly much easier than an engine transplant, I have to ask - why?
#10 redvts
redvts
  • 1,472 posts
Posted 06 January 2013 - 10:58 AM
Loads of revs?
#11 Bumblebee
Bumblebee
  • 7,592 posts
Posted 06 January 2013 - 10:59 AM
Loads of revs?
Stronger engine? Potential to run a lot of horsepower?
Edited by Bumblebee, 06 January 2013 - 11:00 AM.
#12 fezzasus
Posted 06 January 2013 - 11:10 AM
Loads of revs?
Not really, because the K24 has a longer stroke so can't handle as many revs as the K20.
#13 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 January 2013 - 11:17 AM
Loads of revs?
K24 std rev limit is 7200, you can get it to around 8000, my K20 was set to 8600 (std internals) and I think you can go a touch more.
#14 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 January 2013 - 11:18 AM
Loads of revs?
Dont forget V-tec :wub:
#15 siztenboots
Posted 06 January 2013 - 11:20 AM
won't the k24 be a very tall engine?
#16 chrisvx220
chrisvx220
  • 1,036 posts
Posted 06 January 2013 - 11:25 AM
240 na is going to make some nice power down the line with a sc
#17 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 January 2013 - 11:28 AM
Its about 20mm to 25mm higher than a K20 I think
Edited by fiveoclock, 06 January 2013 - 11:28 AM.
#18 fezzasus
Posted 06 January 2013 - 11:38 AM
Loads of revs?
The k24a4 limit is 6800. Possibility because the VCM can't handle higher revs?
#19 VIX
VIX
  • 9,497 posts
Posted 06 January 2013 - 11:47 AM
:yeahthat:
#20 fiveoclock
fiveoclock
  • 9,453 posts
Posted 06 January 2013 - 11:48 AM
Loads of revs?
Yes didnt notice he said A4, you obviously read it more carefully than I did thumbsup
