as above, I have some nimbus heatshield instead of the crap OEM stuff.
Not had any heat issues with mine
Posted 09 February 2014 - 10:37 AM
Posted 09 February 2014 - 10:56 AM
My example was just on the clam part, but with vocky's part you could also protect the sides.
Just buy a sheet of nimbus and get creative.
Posted 09 February 2014 - 11:39 AM
Posted 09 February 2014 - 02:12 PM
Posted 09 February 2014 - 03:02 PM
why not just wrap the manifold like this?
Edited by Dazzx10r, 09 February 2014 - 03:02 PM.
Posted 09 February 2014 - 04:43 PM
Posted 09 February 2014 - 04:47 PM
This is what we did, turbo right next to it and boot inside surface is barely warm. Thermal velocity adhesive backed and aluminum high temp tape to cover the OEM under boot shield.
Posted 09 February 2014 - 08:00 PM
the picture was just to show how close my exhaust manifold is to the clam, I too have the nimbus on the rear clam like Mr Techie's picture
Posted 09 February 2014 - 09:35 PM
And you put this Nimbus over the OEM heat shield?Most of us with aftermarkeyt manifolds use Nimbus on the boot bulkhead, after MartinS' car melted the original insulation. The interior of the boot in my car doesn't even get warm with the Nimbus GII installed. Can only find this picture
The edge you see on the right of the picture shapes to protect the thermostat housing and pipes there, although it gets a bit messy when it comes to removing the clam, as you can see.
Posted 09 February 2014 - 09:39 PM
Posted 09 February 2014 - 09:40 PM
As I have understood it you shouldn´t wrap Stainless manifolds, risk of cracks.
Posted 24 February 2014 - 08:23 AM
Posted 24 February 2014 - 04:54 PM
Posted 24 February 2014 - 04:56 PM
You get an idea of how much one moves from this: Lotus Elise Exige S R 211 Engine Damper Comparison Video
Posted 24 February 2014 - 05:28 PM
Thanks, you got to love the internet. To me it looks like OEM is moving around about 1-1.5cm from center total of 2-3cm, accelertion to Engine breaking. And about half with the Engine mounts. Do you agree? BR, PerYou get an idea of how much one moves from this: Lotus Elise Exige S R 211 Engine Damper Comparison Video
Edited by Aerodynamic, 24 February 2014 - 05:31 PM.
Posted 24 February 2014 - 07:13 PM
Agreed. Maximum looks to be about an inch.
Posted 03 March 2014 - 08:03 PM
Posted 09 March 2014 - 08:08 PM
Posted 09 March 2014 - 10:35 PM
I would shorten that long manifold cone to the point where it is the same dia as your v-band piece, so that moves your cat to the right.
Edited by Exmantaa, 09 March 2014 - 10:35 PM.
