Honda K24 Powered Speedster
984 replies to this topic
#241 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 10 March 2014 - 06:35 AM
I´m no a fan of cutting that manifold, I know this manifold should give me great bhp and the cone is there for a reason. Ofcourse this would make my Life a bit easier, but aloa a bit more boring ;-) Any more ideas? BR, Per
#242 vocky
Posted 10 March 2014 - 08:43 AM
why not move the cat closer to the manifold, chop out the section between the blue lines. Seems silly to reduce and then enlarge the bore size anyway  :unsure:
#243 Arno
Arno
  • 1,238 posts
Posted 10 March 2014 - 09:45 AM
True, but the limited space in these cars means you have to make compromises to get things to fit.
If you really want the maximum power then you should cut the luggage compartiment from the clam and use a manifold that sticks straight out of the engine and goes over the subframe.
Something like this:
Otherwise you have to accept that some tradeoff decisions have to be made between usability and performance in the small area you can work with.
#244 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 10 March 2014 - 03:33 PM
[picture]
I hear what you are saying Arno. And yes compromises are needed all the time building cars or what ever you do. But there are better or worse compromises or better or worse ideas.
Vocky had a interesting idea, even tho I won´t cut it that much, because how I have learned about megaphone headers the reason the megaphone expands in size is because it needs to have a decrease without loosing out in diameter and this sudden decrease is for the sounds pulses to bumb against while you need are for the gases.
Well I just called a Swedish exhaust Company and they were not to afraid of placing the muffler 20cm after the cat. They are also looking into the possibility to modify the muffler like in the Picture below.
And here is where I´m thinking of placing the muffler.
Thanks, Per
#245 techieboy
Posted 10 March 2014 - 03:38 PM
I had a silencer about 2cm after a sports cat on one of my Piper systems, when we were trying to quieten it. No problem there. From memory we even had the post-cat O2 sensor was after that small silencer.
#246 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 16 March 2014 - 08:44 PM
So now when I have reomved my steering rack I´d thought about increasing the castor angle while it´s more accessable.
Whats the upps and downs for adding castor angle?
As I understood is the upps are more negative camber while doing specially Sharp corners (but all corners)
The streight line driving will also be a bit more stable.
The downs is I will loose a bit of steering feeling. Have I understood this right?
What are you guys having?
BR, Per
#247 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 16 March 2014 - 09:04 PM
So even tho I haven´t done much updates here it doesn´t mean I havent done anything.
I have bought a couple of things that I have got home recently.
The last thing I got was a tow hook bracket.
I aslo wanted to make my Life easier when changing to LHD, my initial plan to rework Everything is cut a bit shorter
I also need to save time if I want to drive this year.
So I bought this panel.
I have also started to tear down the front and around the dash panel for my LHD conversion.
It´s very time consuming to be me, I hate rust and I hate broken things in bad condition, maybe a bit of perfectionist.
Just a littlebit tho.
So I had to paint my calipers, am not really satisfied with my car beeing silver so I need som color to it.
And some more painting.
It will also feel great to have some more new parts on
like my new radiator. The Honda Engine is using higher internal pressure for the cooling system
and as I have understood it this radiator is partly built for the higher pressure.
And my new Quick steering rack.
New vs old.
My next brain exercise will come how to easiest convert this pedel to be wire controlled.
Br, Per
Edited by Aerodynamic, 16 March 2014 - 09:08 PM.
#248 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 21 March 2014 - 05:10 PM
I´ve been waiting and collecting parts for gear linkage upgrade from V1 to V1.2. :-)
Posted Image[album][/album]
, Per
#249 fezzasus
Posted 22 March 2014 - 07:58 AM
Hedging your bets with the three mounting points I see!
#250 Dunk
Dunk
  • 1,224 posts
  • Interests:WLTM reliable, quiet, tidy one for LTR.
Posted 22 March 2014 - 08:39 AM
Suggest you speak to DuncanVXR about going to a cable-actuated pedal. I'm fairly sure he installs these as part of the standalone conversion.
#251 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 March 2014 - 10:12 AM
I am not sure I understand what you mean. Probably I don´t
#252 fezzasus
Posted 22 March 2014 - 10:26 AM
There are three holes on the top (in the photo) of the gear selector, I assumed there were three so you could adjust it
#253 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 March 2014 - 10:44 AM
Yes using the top hole makes movement of the stick 12.5cm from end to end position (forward/rearward) next is 11.5 and bottom hole is 10.5. Originally in our Mazda 6 it is 12.5cm so this was the reference. Also the "hook" in the bottom of the rocker arm is to make the push rod about 1cm longer to make the angle of this a Little less, together with bottom hole raised 2mm. BR, Per
Edited by Aerodynamic, 22 March 2014 - 10:49 AM.
#254 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 28 March 2014 - 09:11 PM
Lately I have done repair work on the cooler surronding part in fiberglass. A question, if I want to pain this black, can I use any spray color or is it best to use spray color specially for have on plastic? I´m afraid if choose the wrong spraypaint it can dry out the fiberglass? And it will age faster?! Thak you in advance for the help. BR, Per
#255 fezzasus
Posted 28 March 2014 - 09:18 PM
The fibreglass is dry anyway. It doesn't matter what type of spray paint you use, however you may need to use an etch primer for it to stick.
#256 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 28 March 2014 - 09:47 PM
Ok thank you very much. BR, Per
#257 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 March 2014 - 08:06 PM
This weekend I got more parts delivered
I bought these mandrel bends with Sharp radiu of R114mm. And a 3" muffler. Another Muffler with an S shaped tube inside
is on the way over seas.
Yesterday I got visited by a biker guy who carried these 2 widened Wheels on the bike. Very nice work.
BR, Per
#258 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 10 April 2014 - 08:07 PM
Parts continue to drop in. Yesterday I got my Wheels (black)
and my wifes Wheels back from painting.
Muffler number 2 came from US, hope ´these 2 mufflers and converter will be enought.
[url=http://s954.photobuc...2f976.jpg.html]
#259 Aerodynamic
Aerodynamic
  • 1,455 posts
#260 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 April 2014 - 07:34 PM
So, soe updates needed, since I need your help.
Anyway a Little weekend work
a reworked air distributor box for my LHD conversion
Also trying to figure out what to do with the Electrics and started to look at Engine harness.
Only 2 out of four connectors fits to the ecu, hmmmmm, why?
I also have a complete harness for a Acura RSX (same as Civic type R)
Also figuring where these 2 connectors should fit
Is there any electrical scheme for our cars with connector positions?
Very soon I will start dig into this Electric really Deep.
Also the instrumet in th Spedster is fully analog right?
Last, where do I buy Mintex 1155 for front and rear cheapest?
BR, Per
    Bing (3)
