Honda K24 Powered Speedster
984 replies to this topic
#561 alanoo
alanoo
  • 1,324 posts
Posted 20 August 2015 - 12:40 PM
Aerodynamic, on 16 Jul 2015 - 7:23 PM, said:
Anyone knows ho high OEM tachometer can show?
My scale is going to 8500 but is the hardware capable of this or how high?
How do you guys with higher rev limit solve this?
Br, Per
Indeed, the original needle will simply stop at 7000 rpm.
Vocky and I have found that when revving 8000+  :ninja:
#562 Nev
Posted 20 August 2015 - 01:57 PM
Anyone knows ho high OEM tachometer can show? My scale is going to 8500 but is the hardware capable of this or how high?   How do you guys with higher rev limit solve this?   Br, Per
  Indeed, the original needle will simply stop at 7000 rpm. Vocky and I have found that when revving 8000+  :ninja:
On the VX220 Turbo Stack unit (which is only slightly different to yours) the tacho definitely reaches to where 8000 would be painted on the dial.
Edited by Nev, 20 August 2015 - 01:58 PM.
#563 alanoo
alanoo
  • 1,324 posts
Posted 20 August 2015 - 01:58 PM
Interesting, not the case on the NA model
#564 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 26 August 2015 - 06:45 AM
So can I buy a turbo stack and place in my NA without any re wiring and full functionality? Br, Per
#565 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 August 2015 - 07:25 PM
Almost wanting Winter time by sorting out my car for a full 2016 season
I try to fix some easy stuff now.
Last weekend I wrapped my under dash panels and this weekend I´m hoping to install my Sparco steering Wheel
for  some better steering feel.
I´ve complained aboutmy oversteering and Thinks I start to understand the situation now and will work on this during the Winter time
but till then I am goin to install this on my car Before last track day the 13th of september on Kinnekulle ring.
Next week it will be some cone tracking at Vårgårda Airport.
I really like the Turbo wing and even more the Italitech (or what there name is) elongated version
what is bothering me is that the wing doesn´t take air on the underside. So with this in mind I wanted to do something with similar style
but actually producing some downforce.
This wing will be sitting low, so I don´t get in trouble with Swedish police, and will be possible to adjust higher up for track Days.
Anyone having any idea howto mount this on the backside of the clam?
For next season I will make a diffuser and for track Days a Porsche 911 GT3 RS replica wing , but only for track Days.
Br, Per
#566 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 September 2015 - 11:01 AM
The wing didnt get ready in time as I was hoping and now it´s no panic any more.
This update is a big late, but 2 weeks ago I was at Kinnekulle ring here in sweden.
The day before this Itraditionally went throught the car, placed tools in it, washed it, check engine oil
new brake fluid and also got info to fix my tach with a pull up resistance of 2.2k ohm (I will try a 10k), and I did, when on
test drive the tacho was stone ded and I got stranded at the supermarket parking slot since my battery died.
So the next morning I woke up early I started my battery charger and fixed myself, later on when trying to start the car
it didn´t start. I put the charger on again and while waiting for the battery to charger I decided to cut the wire
so if with the instrument panel steering wheel and surroundng panels and cut it.
Then try to start it it still didn´t work so I had to jump start the car and it started
and so did my tachometer, yay.
I drove my 110km to the track and begun my day slowly. with 90 cars and open pitlane
it ment long ques uphill.
Later on my dad arrived with a starter battery and I could start my first session.
With my rear shock set and 7 from softest instead of 4 as preevious I got into a nice rythm and had a nice feeling for the car.
I still miss a lot of rear end grip tho.
3 sessions in total was OK not the best but still OK.
But on the last session I got an error code, dind´t think much about this. Thought it was probably some lambda or something.
But later when I was going to drive home the car didn´t ran fine at all, I thought it could be because I was lowon fuel
but after filling it up some it didn´t go away. I couldn´t see the engine light but after I learnt it, it was obvious I was in limp mode
2000rpmand 63kmh all the  way home, 110km.
Picture from the kullen
Now time to finish my garage and park thr car there for the winter.
Br, Per
#567 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 September 2015 - 11:17 AM
Finally, this week I got time to check my error code, had to start it to see it.
Thnx god it wasn´t anything more worse.
The car is now not in the register any more for the year.
going to finish up my new garage
and this winter it´s time for refinement.
Br, Per
#568 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 October 2015 - 06:42 PM
#569 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 October 2015 - 04:43 PM
When telling my wife about the modification of the car as seen in the picture above she was saying ok I will look for the papers to fill in for a devorce, I´m thinking of
maybe doing this for next winter.
Also is there any fuel pump that is a direct replacement or easy fit that is recommended for our cars that can handle 400bbhp E85?
I might need this for next year if I should do a SFRO registration here in sweden.
How good or shitty is the OEM rollbar,thinking of installing a new roll Cage or modifiy theOEM roll bar as MAXR have done.
Thank you, Per
#570 vocky
Posted 10 October 2015 - 07:37 PM
if you plan on racing your car then fit a decent roll cage thumbsup
#571 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 11 October 2015 - 04:59 PM
Yhea but putting a X in excisting rollbar should reinforce it a lot, keeping excisting mounts for soft and hard top.
And some bars going close to windscreen surrounding.
And don´t have to put a lot of work taking it out and make a new one.
I´m not planing to race it, just a lot f trackdays.
Anyone having any advice regarding uprated fuel pump?
Anyone have any idea how to lower the driver seat?
Br, Per
#572 Arno
Arno
  • 1,238 posts
Posted 13 October 2015 - 06:25 AM
Check with Gaz here on the site if his fuel pump could handle that. It retains the dual stage fuel pump setup which helps to prevent fuel starvation in fast corners. If not then you may need to switch to a separate swirl pot or reservoir that's filled by the normal fuel pump at low pressure and then use a high pressure, high volume pump that feeds from that. More complicated though and it gives more hoses and reservoirs and other bits that can leak or cause problems.
Actual lowering of the seat itself is hard. Have a look under the seat at how much space is left between the seat and the floor.. About 5 mm :) What is commonly done is to either buy seats that have little or no padding (eg. MOG, Reverie, etc.) so you sit lower 'in' the seat or to use/buy a seat that's tilted back a bit more so your head goes lower and you need to stretch your arms a little more. Bye, Arno.
#573 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 16 October 2015 - 09:14 AM
And again, thanks Arno. ☺ I thought again and maybe I dont need a new fuel pump till 2016 maybe thats for 2017. Will the std pump handle 230 bhp E85? ,Per
#574 Exmantaa
Posted 16 October 2015 - 12:40 PM
If you supply the pump with proper current (thick enough wiring direct from battery (use alternator or startermotor) + relay), it can support around 300-3325BHP on normal fuel.
That is IF you don't go too high in fuel pressure...
#575 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 16 October 2015 - 02:51 PM
So 3.5 bar fuel pessure 220 bbhp on E85, but can it handle the E85?
I mean with seals and so?
Anyone knows how to calculate the size of the injectors needed?
Br, Per
#576 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 December 2015 - 06:10 PM
Not that small update, the last months Ive been working to get my new garage ready and get my Cold wet sweet inside. Posted ImagePosted ImagePosted ImageI´m thinking if I should buy new Wheels and it´s between JR-10 wheels 16*8 ET 20 frnt och 17*9 ET 25 rear only in silver or Team Dynamics pro race 1.2 16*7 ET 20 front och 17*9 ET 25 rear.the rear Wheel weight is the same, JR is wider front and cheaper but I´ve been wanting TDs for many years.plan to run 225/45 16 front.BR, Per
#577 Ormes
Ormes
  • 4,612 posts
Posted 01 December 2015 - 06:55 PM
Nice garage :)
#578 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 02 December 2015 - 06:14 PM
Ormes, on 01 Dec 2015 - 6:55 PM, said:
Nice garage :)
Thank you.
Anyone having any idea abut Toyo R888 n a 7 or 8" rim?
Mvh, Per
#579 Rabiatarik
Rabiatarik
  • 389 posts
Posted 03 December 2015 - 01:54 PM
Nice garage Per!
Do you play music to the car to help it to sleep?
Did you sell all your tools to pay for the garage?
#580 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 04 December 2015 - 05:56 AM
Rabiatarik, on 03 Dec 2015 - 1:54 PM, said:
Nice garage Per!   Do you play music to the car to help it to sleep?   Did you sell all your tools to pay for the garage?
Yes musice is a must to make her sleep. Ni that stereo have been in different stored away for 15-20 years and my wife Asked me to throw it away but I saw the opportunity to have it somewhere. :-) And this new garage is just besides my old garage with a 145cm wide opening in between. Br, Per
