Honda K24 Powered Speedster
984 replies to this topic
#721 2-20
2-20
  • 1,317 posts
Posted 02 October 2018 - 08:39 PM
Ok I got it. Thanks
But is this for all brands? Which brand do you got?
Mine were second hand so i don't know the brand the brand.
You save weight from the inner diameter on all bearings available now (9117622)
But there are also some design variations on the main flange. (where the disc is lying flat) which can show bosses or not but i don't know if they changed flange thickness .
No bosses
Or with bosses
visually, it seems that the part without bosses has a thicker flange to keep the same threaded length and then, should be heavier.
i know that FAG bearings are a "no bosses" design.
#722 2-20
2-20
  • 1,317 posts
Posted 02 October 2018 - 08:50 PM
SKF VKBA 3513 are with bosses
#723 2-20
2-20
  • 1,317 posts
Posted 02 October 2018 - 09:01 PM
Rear window weight is 1.521 kg (Taken from Chris webpage as is below photo)
#724 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 03 October 2018 - 07:43 AM
That would be a tough one to save 3kg from that window.
#725 Rosssco
Rosssco
  • 4,183 posts
Posted 03 October 2018 - 09:22 AM
Which bearings have no bosses / plain flange? I was contemplating the feasibility to re-drill some new bearings to take a 5x114 PCD wheel, and this isn't possible with the version with cast bosses.
#726 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 03 October 2018 - 09:23 AM
looking forward to seeing that wing mounted :)
#727 2-20
2-20
  • 1,317 posts
Posted 03 October 2018 - 10:47 AM
FAG have no bosses
#728 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 03 October 2018 - 04:33 PM
Think a like. One of the main reason to by FAG is they could be possible to re drill for 5/114.3 but I dont know, they seem to have holes everywhere for some unknown reason.
#729 2-20
2-20
  • 1,317 posts
Posted 03 October 2018 - 07:24 PM
Exactly....
The only thing you can do is drill existing hole to 14 mm diameter on a 5x112 circle and install studs...
#730 Rosssco
Rosssco
  • 4,183 posts
Posted 04 October 2018 - 07:55 AM
Pretty sure I've lined up a PCD spacer with 5x114 over an old hub flange (must have been an SKF as it had those 'bosses') and you could place another set of holes between the existing 5x110 holes, and the random hole I don't know what its there for.. Will try double check again tonight if I remember..
#731 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 04 October 2018 - 01:10 PM
Im sure its possible but how much strength will you have left?
But Im interested to see what you can come up with?
#732 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 October 2018 - 04:51 PM
Hows it going Rosssco to see if you can add Another bolt pattern to the hub?
I have a question, I´m looking to make a pulley for a Honda K 7 rib belt but I can find the right
dimensions to use.
Can someone help me to find the right dimensions?
Br, Per
#733 Arno
Arno
  • 1,238 posts
Posted 15 October 2018 - 07:00 AM
What kind of pulley? A driven one (crank) or an idler/tension pulley?
Standard K20 idler pulley is an 31190-RRA-A00 and might be a good template/donor to get info from. Should be on various K20 based civics (also the lower spec K20A3's) in scrapyards.
7PK belts have a standardised groove spacing, shape/angle and groove depth. Some info in here:
https://www.optibelt...BELT_MANUAL.pdf
Probably more to be found if you google around a bit..
#734 Rosssco
Rosssco
  • 4,183 posts
Posted 15 October 2018 - 08:42 AM
I lined up a wheel spacer with 5x114 over a hub (couldn't properly overlay as the center bore / spigot on the spacer was smaller than the hub), but looking at alignment, I think the bolt hole might interfere with the brake disc mounts onto the hub (on the outer edge), so not sure its feasible..
Br, Per
#735 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 15 October 2018 - 04:23 PM
Thanks Arno
I searched and searched and didn´t find anything but then I did.
But your link confirmed the info I found. 40 deg angle and grooved pitch 3.56 for PK belt.
Br, Per
#736 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 October 2018 - 04:02 PM
I´m going to make her a queen.
Project renovating and widening of trailer started.
Here is sidewall removed on right side.
Hopefulle to be finished in 1-2 weeks time and I can start with the Queen after this.
Br, Per
#737 Rosssco
Rosssco
  • 4,183 posts
Posted 20 October 2018 - 09:08 AM
Need some R888's for your trailer.. :P
#738 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 20 October 2018 - 11:09 AM
Then I would need r888 also for my diesel civic aswell for the balance. Maybe it is a good idea. :-)
#739 Jocke_D
Jocke_D
  • 407 posts
Posted 23 October 2018 - 11:27 AM
Have you measured what the absolute minimum size of the bed can be for the Speedster to fit?
Found a small trailer with minimal (but still ok)  "totalvikt" and "tillÃ¥ten maxlast" that will fit my Trafic van. Not sure if the car will fit though...
#740 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 24 October 2018 - 05:20 PM
For your speedster or my?  :-)
My was around 182cm at widest point for rear Wheels.
with this modicifcation I will have around 4cm margin on each side, not much but more then nothing.
, Per
