Honda K24 Powered Speedster
984 replies to this topic
#61 vocky
Posted 23 March 2013 - 10:04 AM
Weekends work. Changed my megaphone header a bit, hope it will work fine like this
My friend who I bought the header from cheap will cry when he sees this.
you need to fit the cat at that point, then loop the exhaust 180 towards the front of the car, then go across to the otherside and loop it 180 once more, then add the backbox and you will have a good performing exhaust.
#62 vocky
Posted 23 March 2013 - 10:11 AM
something like this, except mine crosses the car at the rear of the backbox and yours will need to cross at the front of the backbox
This looped exhaust makes good power on a NA engine Imnotworthy
#63 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 23 March 2013 - 07:55 PM
I would recommend concentrating on getting the engine in and the car up and running first, then deal with "minor" (easier and separate) things like geo. Otherwise you run the risk of trying to do it all in 1 go and making the project too long (and then maybe lose interest). HTH.
Yes, your completelyright Nev. I slowly realise this, deleting a lot of things on the todo list for example changing side
of driving position will come by the end of the summer instead. But I will pepair my front knuckles for more camber.
#64 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 23 March 2013 - 08:00 PM
Nice Vocky.
I have a prettyy good idea on how I will place the pipings. I will split it to two full flow dampers a it will be a 3" exhaust with I
belive a 100 cell catalytic converter.
#65 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 03 April 2013 - 07:42 PM
Hope my machining help can make this for me.
#66 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 11 April 2013 - 08:28 PM
Anyone having an ide how to modify my throttle pedal so it will be for cable? Econominc solutions are preferable. :tt: , Per
#67 Bumblebee
Bumblebee
  • 7,592 posts
Posted 11 April 2013 - 08:29 PM
Dave hardwick did one for mrsimba's car, worth a pm
#68 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 08:34 PM
, Per
I tried a few solutions, but never found one i was completely happy with
starting point:
https://www.elisepar...tle-base-plate/
https://www.elisepar...rottle-linkage/
http://www.cbsonline...Adjuster_M6_CA6
http://www.cbsonline..._Thread_BBJM5LH
http://www.cbsonline..._Thread_BBJM5RH
http://www.cbsonline...able_Long_THCAB
#69 Darcini
Darcini
  • 2,508 posts
Posted 11 April 2013 - 08:38 PM
http://www.davehardw...ttle-pedal.html
#70 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 08:45 PM
nice!
wish that was around when i did mine (back to electronic now)
If you try to mod the standard pedal it doesn't really have enough available movement :(
#71 Bumblebee
Bumblebee
  • 7,592 posts
Posted 11 April 2013 - 08:47 PM
Why do people convert it to cable?
#72 rik
rik
  • 2,187 posts
Posted 11 April 2013 - 08:50 PM
i did it so i could use a dta s40 ecu which has no electronic throttle stuff
#73 Bumblebee
Bumblebee
  • 7,592 posts
Posted 11 April 2013 - 09:29 PM
Oh I see, makes sense now :)
#74 siztenboots
Posted 12 April 2013 - 08:29 AM
they will be putting carbs back on next
#75 rik
rik
  • 2,187 posts
Posted 12 April 2013 - 11:21 AM
I'm surprised the honda engine doesn't want electronic too - or do you not use the factory ecu?
#76 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 April 2013 - 05:15 PM
Thank you, I will look through the links I got.
I´m using a Hondata ECU from a Acura RSX type-r (same as 01-06 civic almost)
and these are not using 1electronic throttle.
The accord tho is using electric throttle, but I don´t think
they have succeed to reprogram the Accord boxes.
#77 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 April 2013 - 09:15 PM
, Per
starting point:
Does it work to modify the VX pedal with this elise parts lever base plate
and throttle lever?
I didn´t find any price on Dave hardwicks pedal.
Regards, Per
#78 rik
rik
  • 2,187 posts
Posted 12 April 2013 - 10:29 PM
it works but i wouldn't recommend it, the pedal doesnt have enough movement to pull the cable enough unless you attach it lower down, and then if you have size 10+ feet your toes are too near the cable :P
there's also the weber pedal from the throttle bodies kit http://www.z22se.co....36/#post-106728
(vocky pic)
Also if you have size 10 feet you are probably approaching 6ft tall - have fun under the dash :beat:
#79 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 April 2013 - 05:20 AM
But this elise part throttle linkage seems to be adjustable? , Per
#80 fezzasus
Posted 13 April 2013 - 07:44 AM
Stupid question, but what's wrong with using the Elise S1 throttle setup?
Edited by fezzasus, 13 April 2013 - 07:44 AM.
