Honda K24 Powered Speedster
984 replies to this topic
#801 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 23 July 2019 - 03:59 PM
That oil cooler can't have any air flow over it at all. Terrible idea
#802 ditonics
ditonics
  • 939 posts
Posted 23 July 2019 - 04:04 PM
Either plumb up some ducting to a shroud
https://www.merlinmo...-brackets-ocd16
Or get some fans on it but you will still need to get the air from outside the car not the engine bay
https://www.merlinmo...matrix-fp113kit
#803 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 23 July 2019 - 07:26 PM
Thank you. :-(
I know its not optimal, but I dont think its that bad. When you have the inner wheel fender in place. It will steer the air around the cooler.
And when I installed the cooler I was told the Honda K didnt need much of an oil cooling, well the cooling is not enough in my car.
I think using a fan and control it is somewat could be good thing in my car.
#804 ditonics
ditonics
  • 939 posts
Posted 23 July 2019 - 07:34 PM
Just remember the ear doesn't actually draw much air in, obviously a fan drawing from the ear will make a huge difference.
Will be interested to see what you do.
#805 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 25 July 2019 - 03:26 PM
I dont have a garage, but trying to manage some small projects anyway.
So here is a small test plate.
Any guess what it is?
Br, Per
#806 FLD
Posted 26 July 2019 - 10:36 AM
I know!
#807 sford
sford
  • 1,451 posts
Posted 26 July 2019 - 10:40 AM
mirror plinth
#808 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 26 July 2019 - 05:53 PM
I guess it was too easy.
I will test this tomorrow and if it fits nice I might print the whole arm.
It will look something like this, minor adjustments could come.
And I Think/hope the PLA platic is strong enough.
I will stick the current metal tube inside of the hole you see in the Picture
Just some spray filler and some paint.
#809 Ormes
Ormes
  • 4,612 posts
Posted 27 July 2019 - 11:44 AM
Something similar on my project :)
http://www.vx220.org...ack-bat/page-10
#810 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 July 2019 - 11:56 AM
I don´t know, not really.
I will cut of the ball joint and stick the metal part inside the arm
so the arm section will be a designed shape.  With a little wing profile. :-)
Counting of producing a massive downforce with this, of about 7 micrograms each side.  :-)
Guess if it will work out good an update for next year would be to paint them with a 2k clear coat.
Br, Per
Edited by Aerodynamic, 27 July 2019 - 11:58 AM.
#811 Ormes
Ormes
  • 4,612 posts
Posted 27 July 2019 - 12:42 PM
Br, Per
I may do the same as the ball joints are sh1t thumbsup
#812 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 July 2019 - 07:14 PM
Exactly I had that moment exactly 1 year ago at Gelleråsen.
In speed above 130 the mirroors tilted in.
I filled the ball joints with Epoxy glue  (Best I could do at the trackday)
Left mirror became alright, but right mirror looks a bit tired, but I don´t dare to touch them. Since they
are in a decent posistion.  :-)
Br, Per
Br, Per
#813 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 29 July 2019 - 12:20 PM
In action at Gelleråsen Arena
https://youtu.be/rvFjM-JfW_0
#814 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 02 August 2019 - 08:48 AM
Next little project started.
Any guess? Hope this one is a bit harder.  :-)
Br, Per
#815 sford
sford
  • 1,451 posts
Posted 02 August 2019 - 09:28 AM
Door hinge spacer
#816 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 02 August 2019 - 11:27 AM
Nope
Door hinge spacer
#817 sford
sford
  • 1,451 posts
Posted 02 August 2019 - 12:04 PM
Side vent?
#818 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 03 August 2019 - 09:54 AM
Yes it is. A good guess.
I will try and make a copy of OEM first.
And then a turbo inspired vent replacing the NA.
I will make it in 2 pieces since my printer only do 215x215mm or so.
Br, Per
Side vent?
#819 alexb
alexb
  • 367 posts
Posted 04 August 2019 - 08:41 AM
I tried that with a piece of aluminum. Not that easy when starting from scratch. In the end I bought Lotushardtops side vents. A lot cheaper that way :happy:. But when fiddling around with that piece of aluminum, I thought it would look better if the vents do not extent to the door, but only part way. That's in case you do not remove the small side panel, like you do when mounting the turbo vents. That way you won't get as much air in as with the turbo vents, but it will be a lot more than with the normal NA grill. Only issue is the mounting of the thing.
The turbo vents work very well, especially with spacers at the back of the diffuser to let the air out. I got the impression that they also generate substantial drag. When you're in for a challenge, you could try to add louvers to the design that you can open and close, with an actuator controlled by some electronics, depending on how much air you need. Like some of the current BMW's have for the main engine radiator.
#820 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 06 August 2019 - 10:57 AM
The idea is they  will be a replacement to OEM NA vent. So no other modifieing of the car than this vent.
I will go down to the garaget later today and measure and take Pictures and do some small templates.
I realize, this will take some time to make it perfect. To fit nicely and look good.
I need a bigger 3d printer for this so I can print it in 1 piece, I will buy a new printer when I move to the new house, dont have space for it now.
I though of making a cover which I can have driving on the road and removing during trackdays, But will se how that works out.
I have other Projects so will not to a temp measuring Active vent, atleast not this time.
I also have other things I´d like to design and print for the car.
But I will upload all things to thingiverse when they are all ready.
Br, Per
Edited by Aerodynamic, 06 August 2019 - 11:03 AM.
    Bing (3)
