Honda K24 Powered Speedster
984 replies to this topic
#81 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 April 2013 - 07:59 AM
Nothing wrong with this I suppose, never thought about this. Anyone know if there is any used for sale?
#82 fezzasus
Posted 13 April 2013 - 09:33 AM
Try contacting junks on Seloc, he regularly breaks elises.
#83 rik
rik
  • 2,187 posts
Posted 13 April 2013 - 09:41 AM
Stupid question, but what's wrong with using the Elise S1 throttle setup?
doesn't have the same mounting points
#84 rik
rik
  • 2,187 posts
Posted 13 April 2013 - 09:50 AM
But this elise part throttle linkage seems to be adjustable?
, Per
yeah it is, but you have to adjust it all the way and end up with a very heavy pedal :(
#85 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 19 April 2013 - 07:48 PM
I try to work on but also house stuff and garden stuff is in between.
I´ll make my own drive shafts I think, these things are beautiful.
An engine mount is read, just need some painting, it stays between the gearbox and std mount.
I ordered some ebay magnetic oil drain pluggs too.
BR, Per
#86 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 20 April 2013 - 10:17 AM
So what do you guys think about exhaust solutions. I want by exhaust to be good for atleast 280bhp. if it is possible to keep the same exhaut for
my supercharged engine up to maybe 370bhp then it´s good too.
So the collector on my exhaust manifold is 3" and the first bend, catalytic converter and first pipe after this will also be 3" then I´m thinking of stepping down to 2.5".
Which to prefer 1, 2 or version 3
I don´t want it to be to loud. My last car was at more or less precise 95dB and this was a bit to much.
S bend silencer
http://butik.arvikae...FLT-500x500.jpg
Regards, Per
Edited by Aerodynamic, 20 April 2013 - 10:19 AM.
#87 vocky
Posted 20 April 2013 - 02:11 PM
2.5" will be fine for 280bhp, but for mid 300's then you might need the full 3" system
#88 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 May 2013 - 07:06 AM
Trying to make the best possible spline, is anyone having any thoughts here?
So I made a variation. With stops on splines, should not affect the turning diameter.
The diameter for the splines are slightly smaller, then outer spline diameter, it has had the same diameter as the narrowest diameter of the Opel drive shaft.
Then I did a variant without stopping heels where joint stops against the splines that grows in radius, but are worried about the risk of the joint cutting into the corner and gives an indication of the splines.
See page 107
http://www.kirkhammo..._aoe/aoe_11.pdf
BR, Per
#89 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 May 2013 - 08:11 PM
If I remember right crandal said that mine was about as good as you could hope without machining at -1.5 and -1.6 on the front with all shims out, and -2.5 on rear. I later changed it to -1.2 and -2.2 as I felt braking was compromised and tyre wear a little high considering I was doing 12-13k a year.
When you say all shims out is this including removing this ABS wire holding shim?
Thinking if I should buy new ABS shims. Anyone knows if I can buy these at Elise shop?
Thanx
BR, Per
#90 fezzasus
Posted 06 May 2013 - 08:44 AM
http://www.elise-sho...f-p-350312.html and http://www.elise-sho...f-p-350311.html (left and right hand side)
#91 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 07 May 2013 - 06:23 PM
Thank Fezzasus. Could you also help me to find the rears, really finding these things on Elis-shop homepage is advanced sh*t.
I´m also looking for Gaiter CV driveshaft boots, anyone know where to buy this with OEM fit and good quality?
Also going to buy Elis shop Aluminium High Pressure extra capacity Radiator and elise-shop Toe Link Kit
Thank you, Per
#92 fezzasus
Posted 08 May 2013 - 02:04 PM
I use this: http://www.deroure.c...CFabLtAodNHIAiw
Find the part of the car you want, then search Elise-shop with the part number.
#93 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 11 May 2013 - 11:11 PM
No, the abs bracket was left in.
#94 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 15 May 2013 - 05:06 AM
Ok thank you.
Edited by Aerodynamic, 15 May 2013 - 05:10 AM.
#95 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 15 May 2013 - 05:11 AM
Lately some parts have droped in and are ready built
Tuner view mfd.
Part for my engine, not many parts are missing now til I can finally start to build my engine.Posted Image
Homemade engine mounts, more or less ready.
Just waiting for my last parts to drop in, so I can start building on my engine.
BR, Per
#96 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 15 May 2013 - 06:18 AM
Nice progress.
#97 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 May 2013 - 08:29 AM
I think it could be good to change the fuel filter now increasing the HP a bit. Is there any high flow fuel filters out there?
BR, Per
#98 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 24 May 2013 - 05:14 PM
Lite mer saker trillat in. Mina drivaxlar (Opel) som håller på och blir modifierade för att passa
Honda inre drivknutar samt några lger hållare för blivande adapter tillväxellänkage.
Some more parts are/have been made. My driveshafts are about to be modified to fit Honda inner joint.
And 3 ball bearing holders have been machined, I´m going to use these for gear linkage and throttle wire
I think.
BR, Per
#99 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 04 June 2013 - 05:04 PM
Been working all weekend. A friend came all the way from Kristiansand in Norway to help.
  It takes time and we have not done much more than getting  the block together . Bbearing clearance measured and piston rings machined to right clearence.
  I struggle on. and now it feels like I can see the light at the end of the tunnel. Engine mounts are ready.  The most important things are on the way, now it's just the rest left
  On Thursday, another friend is comming, Jean-Pierre, so I can get some more time to work with the car.
  This is how it  looks now.
BR, Per
#100 Nev
Posted 04 June 2013 - 05:52 PM
Is that the OEM cylinder liners? Is it a single cast item (ie all 4 liners as a single piece of metal) ?
