Honda K24 Powered Speedster
984 replies to this topic
#161 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 11 October 2013 - 06:06 PM
vocky, on 11 Oct 2013 - 5:26 PM, said:
if anything the cat after the U bend doesn't run so hot on mine
Im a bit confused here Vocky since you wrote in the quote that I should have the catalytic converter directly on the megaphone. But you Think its better to to have the bend first and then the catalytic converter. Yes?
,Per
#162 vocky
Posted 11 October 2013 - 06:52 PM
if you want the cat to work at 100% then fit it on the megaphone, if you want to slightly reduce exhaust heat then fit it after the U bend thumbsup
At the MOT it takes ages for the cat to get hot enough, even after driving around for 45 minutes before I get there :blink:
#163 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 October 2013 - 05:29 AM
Ahh ok cristal. thank you.
Anyone know a good Place to buy mandrel bends and good flowing mufflers with good prices?
BR, Per
#164 Ormes
Ormes
  • 4,612 posts
Posted 12 October 2013 - 08:24 AM
How long until the project is on the road and the first video posted?  Looking forward to it! thumbsup
#165 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 October 2013 - 08:36 AM
I haven´t done anything really the last 2-3 months. But I will try to get started again.
I hope I will be able to test drive it Before new year.
The real goal is to have it ready by april.
With a new diffusor and LHD converting and gauges and so on.
BR, Per
#166 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 20 November 2013 - 08:42 PM
vocky, on 23 Feb 2013 - 09:21 AM, said:
engine bay coolant pipes. gearbox side: large = return from radiator, small = return from heater engine side: large = warm coolant to radiator, small = warm coolant to heater
So the Opel Engine have the water intlet on the gearbox side and outlet on motor side.
The Honda Engine have the opposit it seams and it would be much more simple if I could run the water in the other direction, would this be possible without any major modification?
#167 fezzasus
Posted 21 November 2013 - 07:30 AM
I would swap the radiator hoses for the toyota elise parts. They have the bleed valve on the other side because the water also runs in the other direction.
#168 fezzasus
Posted 21 November 2013 - 07:31 AM
These: http://www.elise-sho...2-p-502149.html
#169 vocky
Posted 21 November 2013 - 08:50 AM
a few of problems reversing the flow ......
1: as stated above, bled nipple on wrong side of rad = change rad hoses for elise versions
2: the oil cooler would get the hottest coolant (going to the rad) rather than the coolest (from the rad) = fit an air cooled rad rather than the water cooled version
3: the coolant reservoir would 'back fill' - this would be the biggest issue = move the reservoir hose to the heater circuit
Edited by vocky, 21 November 2013 - 08:51 AM.
#170 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 21 November 2013 - 07:15 PM
No 2 and 3 wouldnt be a problem since I will delete the oil cooler and get a air oilcooler instead, which I aklready have.
I need to change a lot of hoosing anyway since this doesn´t fit with the Honda Engine.
But else there is no 1 way walve in the system or some other issues like you want the inlet wate on a high side ad outlet in low
or anything like this?
Where is the beed nipple located? Ho does the water resorvair tank works? The thick pipe in bottom is comming from inlet water and the thin higher pipe is going to the outlet water engin. Is the height of the locationcompared to the Engine very important? Or does itjust need to stay above the highest water Place in the system?
Br, Per
#171 vocky
Posted 21 November 2013 - 08:42 PM
no valves to worry about, I cannot think of any issue running the coolant the other way.
Bleed nipple is usually on the left hand side of the rad, but is on the right hand side on the elise.
The reservoir needs to feed extra coolant at a similar place to where Honda use in the civic coolant system, so you might be able to adjust the hoses to suit.
#172 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 November 2013 - 04:41 PM
I was looking for  wilwood rakdisc for alubells, but they onl have discs that are 20mm width or 28mm
How would any of theedisch fit with std caliper.
Aso I´m not able to past any link fromphotobe into hear any longer.
Does nyone know why it´s ilike that?
Br, Per
#173 fezzasus
Posted 22 November 2013 - 05:59 PM
Cheapest place is elise parts - they sell them for around £300 per pair. I do have a pair of Aluminium bells for AP discs going spare if you're interested, however the AP discs are around £400, so not the cheapest approach.
#174 Winstar
Winstar
  • 4,264 posts
Posted 22 November 2013 - 10:42 PM
Br, Per
the coolant reservoir also usually set the minimum pressure in the system so need to be plumbed in at the inlet to the water pump.
#175 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 24 November 2013 - 03:39 PM
Does anyone know why I can´t any longer copy a link and paste it in this forum?
BR, Per
#176 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 26 November 2013 - 07:44 PM
Running the coolant the other way, no worried either for the heater line either?
Br, Per
#177 vocky
Posted 26 November 2013 - 08:16 PM
standard heater can work in both flow directions, fezz upgrade heater will need the valve turning around
#178 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 27 November 2013 - 10:10 PM
Thank you Vocky
#179 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 28 November 2013 - 05:43 PM
Major mile stone.
Det senaste har jag försökt ligga i lite. har jag inte mekat har jag försökt göra lite research.
Bland annat tror jag att jag har löst kylar systemet genom att jag har köpt en sådan här
som kommer kopplas med ett T-kors vid utgången på kylsystemet från motorn. Denna ihop med
et Honda expansions kärl så kommer det funka som Honda OEM kylsystem (tror jag)
Jag kan inget om sånt här så jag gjorde det för det verkar enkelt och liknar original.
Sen till det roliga.
It´s airborn, ja alltså motorn sitter i på sina riktiga motor fästen och allt passade, detta efter lite skohornande, bokstavligt talat. Det enda som jag inte är riktigt nöjd med är att Generatorn kommer så nära torped väggen vilket jag inte är helt nöjd med. Jag har distanser som bygger ut generatorn 15mm pga att jag inte köpte rätt generator och sen har fel remlängd och remskiva.
Detta känns så skönt.
Nu ska jag försöka börja koppla in allt med.
På återseende.
Med vänlig hälsning, Per
#180 Ormes
Ormes
  • 4,612 posts
Posted 28 November 2013 - 06:36 PM
Have the English upset you? :) Any chance of a translation?
thumbsup
7 user(s) are reading this topic
    Bing (6)
