Service & Fix-Up 2013
Posted 06 January 2013 - 09:25 AM
Posted 06 January 2013 - 09:40 AM
Posted 06 January 2013 - 09:48 AM
Take the air hose off, it just pulls out
Yea sure, but then it looks like this after a few years:
https://drive.google...dk9OQjVjX0UtTGs
Posted 06 January 2013 - 10:14 AM
Posted 06 January 2013 - 10:31 AM
Posted 06 January 2013 - 11:09 AM
Posted 06 January 2013 - 11:19 AM
If i'm honest, I don't see the point. The battery should last at least two years, usually longer. The effort of pulling off a hose every two years is minimal.
Every fall and spring i have to pull out the battery, due to BAD cable making from previous ownership there's leakage in the circuit so power draws every now and then.
But even then, it's tight as hell due to the cable stem, the way the hose is connected today it's bad, slip-on == leakage and it's not perfect.. and i don't like design where something is in the way of other things.. if i want to take out the battery, something shouldn't be in the way..
Posted 06 January 2013 - 11:54 AM
I'll definitely get a new hose but i'm also thinking of changing to a smaller battery or add a alu angle connector to the hose inlet so the hose starts to the right (left on the vx220?), makes the distance smaller and the connector won't bother the battery if i need a full size battery at the end.
Get a smaller battery from TAT. So easy to fit.
Posted 11 January 2013 - 08:40 AM
Since I'm no mechanic I take things slow and I'm extra careful..
But last night i had to use some force in order to get the inside of the car out!
And as a little bonus:
Posted 11 January 2013 - 09:12 AM
Posted 11 January 2013 - 09:14 AM
you're running a mobile VPN service from your car?
Ofc?
I use it to tunnel things back to home (for instance GPS data, and if no VPN is present then it gets sent via gmail and IMAP)
Edit: Noticed the hostname on my host is wrong, should be VPN client..
It used to be a VPN server, but i swapped it for a RasPi Model B Rev2, the one in the picture is a Rev1 (less ram)
Edited by Anton, 11 January 2013 - 09:19 AM.
Posted 11 January 2013 - 09:27 AM
Posted 11 January 2013 - 09:43 AM
You're such a geek Ray
Posted 11 January 2013 - 09:45 AM
Posted 11 January 2013 - 10:07 AM
Or perhaps even send me £20 (Shipping and HW costs, nothing for myself in this) and i'll ship both the hardware, software and instructions on how to plug it in
This will later go between the ECU and Ignition lock and be placed in a hard spot to reach so it'll take at least 2h to get it out giving me enough time to drive halfway across Sweden before they can jank it out.
It will also control the headlights Angle, because even at the lowest "setting" i get a mark at the inspection saying they're to high..
And a mark here means you're not allowed to drive basically..
So, these are to be fitted:
http://www.theretrof...products_id=927
And since it includes a high-beam inside it this will replace the entire headlight functionality.
So adding "extra headlights" will be done in the normal high-beam housing giving me just about godlike light in the dark hopefully
With a servo connected to the RPi which i yet to figure out how to control, i don't want to many buttons inside so i'm thinking of a WEBgui which i can run from the phone, or automatic via light-sensor which reads the reflected light and if there's to much it lowers the beams (which would be great when meeting cars in the dark because i would never have to worry about blinding other drivers)
Edited by Anton, 11 January 2013 - 10:17 AM.
Posted 11 January 2013 - 12:04 PM
I'll post the details of all the new features i add to the car, so if anyone's interested in programming you could use it as a DYI kit.
keep me updated, yes I'm a geek and love nerdy stuff like this
Posted 11 January 2013 - 12:05 PM
You'll be nice to me if you want some Tim Tam Double Chocolate biscuits imported direct from the colonies
Posted 11 January 2013 - 12:15 PM
Posted 11 January 2013 - 12:22 PM
hehe will do ;D
Where's it getting it's GSM/3G/4G connection from?
A USB Huawei dongle mounted around the back,wasn't attached in the picture above tho.
Posted 11 January 2013 - 12:26 PM
Also tagged with one or more of these keywords: Pictures, Ideas, Videos, Speedster, 2.2 N/A
General Discussion →
Tuning & Modifications →
Bizarre Acceleration IssueStarted by MattMacc123 , 10 Aug 2019 acceleration, vx220, speedster and 2 more... |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Mallorca With An Opel SpeedsterStarted by judgefargo , 19 Mar 2019 speedster |
The Market Place →
Car Parts For Sale →
Airbag For SaleStarted by oeccse , 21 Nov 2018 airbag, air bag, speedster, vx220 and 4 more... |
VX220 Discussion →
Help To Identify My Exhaust Back Boc PleaseStarted by Mr Z Ombie , 11 Apr 2017 2.2 n/a |
Guides and Tutorials →
Postcat Lambda Change Tutorial - P0140 - The Pictures EditionStarted by martinroger , 04 Feb 2017 lambda, sensor, exhaust, tutorial and 1 more... |
