Just Fitted Vxt Cross Drilled Discs!
#1 Guest_M17D VX (Guest)
Posted 27 April 2003 - 03:13 PM
Posted 27 April 2003 - 03:36 PM
#3 Guest_M17D VX (Guest)
Posted 27 April 2003 - 03:42 PM
Posted 27 April 2003 - 04:19 PM
May I ask what difference you notice?There is a noticeable difference
If I were buying a new VXT, I would specify cross-drilled to be sure to get the maximum. It's just that, especially since having the ABS upgrade, the standard N/A brakes themselves seem fine even on track. By that I mean that I have never experienced any suggestion of fade. The braking effect itself could definitely be improved. Some Porsche and Ferrari rear ends have been unnervingly close at times! The limiting factor to me seems to be the narrow width of the front tyres preventing better braking. So am wondering if swapping really makes sense. Are you saying that it actually stops better with the cross-drilled?
#5 Guest_M17D VX (Guest)
Posted 27 April 2003 - 05:23 PM
Posted 27 April 2003 - 06:11 PM
Posted 27 April 2003 - 06:34 PM
Posted 28 April 2003 - 08:37 AM
Yep, can confirm that - much more initial bite and at least on par with VXT Cross drilled set up. As soon as my VXT arrives I'll upgrade the pads - that should be all I'll need for track work toochange the pads...... it will make a massive difference!! ask thorney!
Posted 28 April 2003 - 09:49 AM
I will have to ask if anyone over here has them fitted and how good they are.
http://www.moto-conc...p?item_id=15369
John.
#10 Guest_Guest (Guest)
Posted 28 April 2003 - 11:00 AM
Yes. I've seen these and wondered too if anyone can report on how they are. They claim that their special treatment makes them very resistant to cracking. Claim that far better than Opel orig. euipment. They also recommend painting the parts of the disc that are not in contact with the pads with Hammerite.discs from Germany
Interesting to note that Pagid RS14/15 pads are not permitted for road use in Germany and thus certainly not in Switzerland too, but the Moto-Concept ones - as used on the MS-Design 2.2l Turbo S Limited - are.
Posted 28 April 2003 - 11:04 AM
Posted 28 April 2003 - 12:52 PM
