Nitron Ntr Questions - Ie How Does One Swap Springs?
Posted 13 January 2013 - 03:52 PM
Posted 13 January 2013 - 04:08 PM
Posted 13 January 2013 - 05:00 PM
1) With Ntrs fitted my front wheels are closer to the arches than when the car is sat on the ground at std ride. When I let the jack down they barely move and this still results in 100mm ride height which is a bit low.
And ideas why this might be? Is this something to do with brackets?
You do have the VX specific types?
2) How in gods name do I get the springs off? Can you just not do it yourself? This would be insane!!
1> Remove from car
2> Loose off the upper spring seat until spring is free from bottom seat
3> slide bottom seat upward a little, exposing snap ring
4> Use pliers to open up snap ring and remove from seat base
5> Slide lower spring seat over base (will go over now that snap ring is removed)
6> Remove spring from damper
Refitting is reverse
Posted 13 January 2013 - 05:32 PM
Posted 13 January 2013 - 08:34 PM
Posted 13 January 2013 - 10:58 PM
And some from the forum (for sale 2009) http://www.vx220.org...-sport-dampers/
They do look the same.
(Other than shineyness - Steve, not preload, just you cant get the platform far enough up the rod to see whats underneeth it.
Edited by JohnTurbo, 13 January 2013 - 11:00 PM.
Posted 14 January 2013 - 08:34 AM
Posted 14 January 2013 - 09:01 AM
Posted 14 January 2013 - 09:31 AM
Posted 14 January 2013 - 08:05 PM
Posted 14 January 2013 - 08:47 PM
Do this
The platform near the lowest arrow......
Unwind it as far as it will go.
Then
push the spring all the way down too.
Then the platform near the top arrow will move down too. It may need a little persuading. When this moves down it will expse a snap ring.
Remove snap ring
Then move the collar UP and off the shock.
The spring will then come UP off the shock too
Posted 14 January 2013 - 09:30 PM
Posted 14 January 2013 - 09:39 PM
Posted 15 January 2013 - 08:55 AM
Posted 15 January 2013 - 10:48 AM
