Sorry, what does that mean?
#2041
Posted 17 April 2017 - 11:19 AM
#2042
Posted 18 April 2017 - 01:55 PM
Is the idle vacuum condustant ??
i mean constant
#2043
Posted 19 April 2017 - 09:40 AM
No, idle is not stable:
A vacuumleak should not cause this I think, because of the TMAP sensor.
The idle is hunting a bit.
Edited by TFD, 19 April 2017 - 09:41 AM.
#2044
Posted 19 April 2017 - 09:47 AM
Take a look at the ignition at idle:
Above graph is Chill's car at idle (old file I had around) and the below graph is my ignition at idle. Looks all over the place...
#2045
Posted 19 April 2017 - 09:54 AM
Also noticed that Chill's throttle/fly % (throttle-tab) is lower then mine at idle. Could be a cause? Will try out at home.
#2046
Posted 19 April 2017 - 10:16 AM
Is red the throttle pedal position?
#2047
Posted 19 April 2017 - 10:19 AM
Yes it is the VALVE.
Good thinking. So something makes the valve bounce open/close. This does not happen at Chills log.
Dodgy TPS? No DTC's popped up.
Edited by TFD, 19 April 2017 - 10:24 AM.
#2048
Posted 19 April 2017 - 10:21 AM
#2049
Posted 19 April 2017 - 10:23 AM
#2050
Posted 19 April 2017 - 10:31 AM
bottom red is throttle valve (TB)
bottom black wiggly is ignition
and top blue is map
#2051
Posted 19 April 2017 - 10:32 AM
TFD what date is my log from
#2052
Posted 19 April 2017 - 10:34 AM
Also look at the log and select the two pedal position tick boxes (pot 1 and pot2)
number 7 red and blue
should work opposite each other
Edited by CHILL Gone DUTCH, 19 April 2017 - 10:37 AM.
#2053
Posted 19 April 2017 - 10:37 AM
21-4-2016
Top blue is your ignition, not the MAP. I've did some PAINT-skills over there to make a comparrison.
#2054
Posted 19 April 2017 - 10:40 AM
i will send you my email- by pm
send me your log and i will take a look at it
#2055
Posted 19 April 2017 - 10:41 AM
You allready have my log in your mailbox
Here's the comparrison:
The Throttle pedal stays at 0%, but the throttle valve fluctuates in my log.
Edited by TFD, 19 April 2017 - 10:42 AM.
#2056
Posted 19 April 2017 - 10:53 AM
#2057
Posted 19 April 2017 - 11:01 AM
i would alter the throttle map and see if it improves,
will take a look at the log now ( i forget what i have )
#2058
Posted 19 April 2017 - 11:04 AM
Is that cold idle or warm?
That's warm. But some issues as well when cold.
#2059
Posted 19 April 2017 - 11:19 AM
i wonder if the ecu is telling the throttle valve (TB ) to increase to stop stalling
try and increase you idle RPM to 1000 from 950
i noticed the rpm is dropping below 900 so ecu might be trying to compensate
also have a play with the maximum throttle valve speed in the transient tab
#2060
Posted 19 April 2017 - 11:22 AM
might be worth trying my transient setting on that whole page as there quite a bit different from yours
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
