obdtuner remap z22se ecu
2116 replies to this topic
#2061 CHILL Gone DUTCH
Posted 19 April 2017 - 11:31 AM
and put the map delta difference 0% (0.0) to 0.8
in transient
Edited by CHILL Gone DUTCH, 19 April 2017 - 11:31 AM.
#2062 TFD
TFD
  • 607 posts
Posted 19 April 2017 - 11:41 AM
Will have a go tomorrow, cheers.
#2063 CHILL Gone DUTCH
Posted 19 April 2017 - 11:51 AM
here are my settings
pay special attention to the 0% map delta difference
and the throttle speed at 1000rpm  when stationary
#2064 Exmantaa
Posted 19 April 2017 - 11:59 AM
These are different type TB's, right? And what injectors are fitted Daan??
@TFD; the ecu notrmally controls idle rpm fluctuationswith ignition changes (fast) and if that is not sufficient it will start using the TB flap (slow).
Normally when you have a vac leak the ecu closes the TB flap fully and then starts retarding ignition to lower rpms. Your's is doing somethng different. EGR is removed I assume? Maybe a dirty TB flow (clean) or maybe, if still fitted, the EVAP valve is leaking fuel vapours at idle? (temp close off?)
Just thinking out loud...
#2065 Exmantaa
#2066 TFD
TFD
  • 607 posts
Posted 19 April 2017 - 12:32 PM
I'm using the 58mm stock TB and Chill is using the 68 of LV4? TB.
Injectors are the vxr 470cc blue ones.
EGR is removed and blanked off.
Will check the vacuumlines, give the TB a good clean and check the connectors.
Ofcourse... after i tried the maps... cause that's a lot easier to do  :P
(allthough my gut says it's a mechanical thing..)
#2067 CHILL Gone DUTCH
Posted 19 April 2017 - 12:39 PM
they were my 68mm TB settings
tbh ive never used the 58mm TB
#2068 Exmantaa
Posted 20 April 2017 - 10:36 AM
Also check the evap line from the charcoal cannister (simply block off to test)
#2069 TFD
TFD
  • 607 posts
Posted 20 April 2017 - 04:59 PM
Thanx guys. Will test stuff this weekend if I can find some time.
#2070 TFD
TFD
  • 607 posts
Posted 23 April 2017 - 05:37 PM
Cleaned the throttlebody and it is shiny again:
Moved the evap from the manifold to the intakepipe.
No improvement on idle. The evap can now always relieve cause of the permanent vacuum on the intakepipe.
Did some driving and learning etc. At home I found out that the idle sounds better when I adjust the ignition timing at the "idle"-tab.
At 20kpa it says 9.6 ign.timing.
At 30kpa it says 5.4 ign.timing.
Now my vacuum at idle runs between 29-31kpa, so I think this may cause the timing hunt...
When I adjust the timing at 30kpa to 11ish ign.timing the idle sounds smooth.
The throttlevalve is also more steady now. Will post a pic.
Have to clarify this tomorrow as I had limited time left.
Edited by TFD, 23 April 2017 - 05:40 PM.
#2071 oakmere
oakmere
  • 2,143 posts
Posted 23 April 2017 - 09:54 PM
That is what I would have advised if running higher lift cams. Std cam setup is normally happy with the std settings? Set all idle ignition cells the same and make sure the main ignition table is the same or higher than your idle ignition. What you don't want is a sudden drop in ignition or the engine dies as you pull away.
#2072 CHILL Gone DUTCH
Posted 24 April 2017 - 05:30 PM
looks like peter is still working hard
another update ( PRO )
  • Less aggressive settings for P3501 for wideband fuel control.
Edited by CHILL Gone DUTCH, 24 April 2017 - 05:35 PM.
#2073 TFD
TFD
  • 607 posts
Posted 25 April 2017 - 11:24 AM
I remember you saying this some time ago and that's why I gave it a go.  thumbsup
#2074 TFD
TFD
  • 607 posts
Posted 01 May 2017 - 06:47 AM
Issue seems to be solved! Retarded the throttle/valve relation and added some more timing to the 30kpa cell at the idle-tab. Can take off easely now without pushing the throttle.
I think there can be some more efficiency gained on the intake part. Like the OEM N/A setup, the IC pipes are connected on a 90 degree angle to the throttlebody. This is not a good situation when it comes to flow.
Will fix that if I make a different intake manifold.
#2075 Nev
Posted 01 May 2017 - 12:12 PM
the  pipes are connected on a 90 degree angle to the throttlebody. This is not a good situation when it comes to flow.
The Z20LET setup is like this and even though the OEM setup seems to drive fine, I always wondered about it.
#2076 CHILL Gone DUTCH
Posted 01 May 2017 - 03:23 PM
Good news you have resolved the issues
#2077 TFD
TFD
  • 607 posts
Posted 01 May 2017 - 04:01 PM
@nev: The less bends the better.. especially so close to the throttle. Makes to much turbulance. Think about fitting a SR20DET intake manifold who has a direct connection. @Chill: Thanx for the effort!
#2078 CHILL Gone DUTCH
Posted 01 May 2017 - 04:23 PM
Can you email me a copy of your current file please for my records and can see what you have changed in detail
#2079 ufods
ufods
  • 235 posts
Posted 07 May 2017 - 07:38 PM
I buyed a windows tablet to avoid taking my big Laptop in the car but i cannot get the connection to OBD Tuner. In the device manager i do not see my elm 327. Any ideas?
#2080 smiley
Posted 07 May 2017 - 07:47 PM
Cabled or bluetooth?
