obdtuner remap z22se ecu
2116 replies to this topic
#2081 ufods
ufods
  • 235 posts
Posted 07 May 2017 - 07:48 PM
Cable.
#2082 CHILL Gone DUTCH
Posted 07 May 2017 - 07:50 PM
DOes it show up in your device manager with a yellow triangle
#2083 ufods
ufods
  • 235 posts
Posted 07 May 2017 - 07:57 PM
Device manager shows nothing. When in my laptop i see the elm in the device manager, look for the com port and add it in the obd Tuner software. There is an Adapter from micro usb to usb between....maybe this thing is faulty.
#2084 CHILL Gone DUTCH
Posted 07 May 2017 - 07:58 PM
Is it a " on the go adapter " OTG
#2085 ufods
ufods
  • 235 posts
Posted 07 May 2017 - 08:00 PM
Sorry...What is otg ?
#2086 CHILL Gone DUTCH
Posted 07 May 2017 - 08:01 PM
" ON THE GO "
#2087 ufods
ufods
  • 235 posts
The device is an chuwi HI 8 tablet
#2088 CHILL Gone DUTCH
Posted 07 May 2017 - 08:03 PM
https://www.ebay.co....tm/282175699892
#2089 ufods
ufods
  • 235 posts
Posted 07 May 2017 - 08:08 PM
Sorry....had to google otg first 😃 The manual said the adapter is otg...but it is a try to change this part.
#2090 ufods
ufods
  • 235 posts
Posted 10 May 2017 - 05:18 PM
Hurray for Chill!!!! OTG was the reason 😃 Thanks man....
#2091 CHILL Gone DUTCH
Posted 10 May 2017 - 05:29 PM
I got info of techie
#2092 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 18 May 2017 - 12:47 PM
Is anyone using this wideband controller ?
https://www.amazon.c...=A2QTCKCW6VODUD
Includes a narrowband output which i would assume means that only a wideband lambda be installed and the narrowband fed to the ecu to keep it happy ??
whats the opinion ??
#2093 CHILL Gone DUTCH
Posted 18 May 2017 - 01:23 PM
as you have posted on the dutch thread i assume your running the dutch software,
probably not a great idea as you should be using oem lambdas
money will be better spent if you get the pro version of the software as its not required to use the second lambda and you can use a wideband instead
#2094 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 18 May 2017 - 01:58 PM
Yes i am
thank you for your answer, can a wideband be used after the cat though ? wont this compromise the AFR measured ?
#2095 CHILL Gone DUTCH
Posted 18 May 2017 - 02:09 PM
lose the CAT
you might find a wideband so close to engine side wont last very long
Edited by CHILL Gone DUTCH, 18 May 2017 - 02:10 PM.
#2096 CHILL Gone DUTCH
Posted 18 May 2017 - 06:05 PM
more updates for pro
http://www.obdtuner....PgDownload.html
#2097 oakmere
oakmere
  • 2,143 posts
Posted 24 June 2018 - 08:32 PM
Just for other people’s information if having similar issues.
I have vastly improved the way the car pulls away from a standing start. I have achieved this by adding quite a bit of fuel into the 600-800 & 1000 rpm area of the fuel map (30%-25% & 20%). The totally std oem map also has a lot of fuel added in this area.
I how don’t have to worry about stalling the car when pulling out of junctions etc.
Edited by oakmere, 24 June 2018 - 08:34 PM.
#2098 rik
rik
  • 2,187 posts
Posted 25 June 2018 - 11:25 AM
I know the post cat lambda check can be disabled, but does it still need to be present/plugged in? Little problem where it's sheared off and then the bolt extractor sheared off too! So it's now safely plugged up at least, but do I need to leave a new sensor hanging?
#2099 oakmere
oakmere
  • 2,143 posts
Posted 26 June 2018 - 11:27 AM
The post cat sensor is required as it is used by the ECU for checks so can’t be removed.
#2100 rik
rik
  • 2,187 posts
Posted 26 June 2018 - 11:30 AM
Required to be plugged in to exhaust stream or just plugged in to loom?
