obdtuner remap z22se ecu
2116 replies to this topic
#2101 oakmere
oakmere
  • 2,143 posts
Posted 26 June 2018 - 12:40 PM
Exhaust stream or it will throw error codes.
#2102 rik
rik
  • 2,187 posts
Posted 12 August 2018 - 11:55 PM
Getting tired of my clone elm327 bluetooth device needing to be reset all the time
however, having trouble finding a genuine elm 327 device such as this one is out of stock https://www.scantool...-interface.html
anyone used the newer STN1110 based obd devices with obdtuner?
- https://www.obdsol.c...d-obd-adapters/
https://www.scantool...id-windows.html
#2103 chris_uk
Posted 13 August 2018 - 12:12 AM
does it have to be bluetooth?
i have this one and has worked flawlessly.
https://www.ebay.co....3.c100505.m3226
#2104 rik
rik
  • 2,187 posts
Posted 13 August 2018 - 12:18 AM
the one i have is the bluetooth version of that one (same sticker at least). To be fair, it's only the bluetooth connection which is a bit crap, once connected it's fine
I'll keep it in mind
#2105 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,121 posts
Posted 13 August 2018 - 06:09 AM
I have the one with the usb lead and it works no problem. I did hear that the BT ones were a bit flakey.
Eta try getting the phone close to the obd2, I use a BT one for fault codes and found it needs to be close.
Edited by Sutol, 13 August 2018 - 06:12 AM.
#2106 fezzasus
Posted 13 August 2018 - 05:00 PM
OBD tuner manual specifically advises against using bluetooth
#2107 paul_mck
paul_mck
  • 284 posts
Posted 03 June 2019 - 08:27 AM
bit of a bump - are these still available? I notice http://www.obdtunercom is down.
#2108 border
border
  • 19 posts
Posted 03 June 2019 - 08:44 AM
You're missing the '.' in '.com'  thumbsup
#2109 paul_mck
paul_mck
  • 284 posts
Posted 03 June 2019 - 08:47 AM
lol its straight from this page: https://www.verboom..../ecu/index.html
actually is odbtunercom.com on there. got it now cheers, trying to find pricing
#2110 border
border
  • 19 posts
Posted 03 June 2019 - 08:50 AM
I had to email Peter for pricing - 885EUR for obdtuner and 1275EUR for Pro (or at least that's the price he gave me a couple of weeks ago)
#2111 paul_mck
paul_mck
  • 284 posts
Posted 03 June 2019 - 08:51 AM
cheers border - thats your ecu posted over and returned with new firmware?
#2112 border
border
  • 19 posts
Posted 03 June 2019 - 08:59 AM
yep, lifetime software licence, base map, return shipping and 1-year email support included
#2113 paul_mck
paul_mck
  • 284 posts
sweet - thanks mate!
#2114 rik
rik
  • 2,187 posts
Posted 23 June 2019 - 07:13 AM
When lift off throttle, e.g. going down a hill, courtenay map would stop injecting fuel and AFR would go super lean
With obdtuner map in same situation, AFR is still maintained at 14.7
Is it like that for everyone else? Pros and Cons (fuel consumtion, less engine braking?)
What would I have to set on my obdtuner map to make it pull the fuel when lifting off?
Thanks!
#2115 TFD
TFD
  • 607 posts
Posted 30 June 2019 - 05:10 PM
Coasting/lift should result in an 22xx afr. Has normally nothing to do with the software you are running, more with what you do with it.
#2116 Tommo
Tommo
  • 344 posts
Posted 08 July 2019 - 02:36 PM
has anyone run Peters software on a macbook via parallels?
seeing as my ECU arrived today having taken a 4 week tour of northern Europe (courtesy of DHL), i'll hopefully get cracking on this at the weekend.
#2117 paul_mck
paul_mck
  • 284 posts
Posted 08 July 2019 - 02:38 PM
Id go with Windows running in VirtualBox, worked well for any VCDS type stuff Ive ran before. You can download trial Windows images from Microsoft
