obdtuner remap z22se ecu
2116 replies to this topic
#281 techieboy
Posted 19 February 2013 - 01:19 PM
go on you know you want too !
You won't need one with the new software. Just switch it off in the software. Undoubtedly just in time for the first O2 sim to be produced.
#282 Baron Von Scubadaddy
  • 6,644 posts
Posted 19 February 2013 - 01:41 PM
This is my problem !!!!
#283 slindborg
Posted 19 February 2013 - 02:38 PM
the first one has been running for about a year now in Lee's car :lol:
FLD, its ok, take her out more often, saves me the hassle :D
#284 FLD
Posted 19 February 2013 - 03:12 PM
If it gets me a lambda sim then sure!
#285 smiley
Posted 19 February 2013 - 03:51 PM
What´s with the lsj injectors on your NA scubameister? The oem´s can go up to 200 horsies before maxing out. What are you doing?
#286 Baron Von Scubadaddy
  • 6,644 posts
Posted 19 February 2013 - 04:03 PM
not fitting the lsj injectors now !!!!! thanks smiley i love this place far too many cool and clever people ! thank you
#287 smiley
Posted 19 February 2013 - 04:31 PM
No worries, you just scared me there. Keep them in a safe place for your future SC conversion.
#288 Baron Von Scubadaddy
  • 6,644 posts
Posted 19 February 2013 - 04:33 PM
yep roger that !
#289 rik
rik
  • 2,187 posts
Posted 24 February 2013 - 06:43 AM
very interesting, contemplating ditching my dta for this boring question but does the immobiliser still work? if so when I buy a spare ecu on ebay how does he/I code it to my key etc?
#290 CHILL Gone DUTCH
Posted 24 February 2013 - 08:07 AM
I'm guessing you would need to have a ECU which already works with car if immobiliser still works
#291 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 24 February 2013 - 09:04 AM
I have Rik,
Do you still have your old ecu? Drop Peter a pm and see what he can do. If he can't just pick up a one on eBay with 2 chips and a transponder easy to fit
#292 smiley
Posted 24 February 2013 - 11:20 AM
Yes, immobiliser still works.
If you have the famous 4 digit code for your current immobiliser, Peter can code that into your ebay ecu.
#293 rik
rik
  • 2,187 posts
Posted 24 February 2013 - 12:00 PM
dont have the code :( my car was a cat d so I didn't get anything with it... hoping my old ecu is somewhere at my parents place as I've not seen it for years :P r u gonna do it too nick?
#294 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 24 February 2013 - 12:07 PM
dont have the code :(/> my car was a cat d so I didn't get anything with it...
hoping my old ecu is somewhere at my parents place as I've not seen it for years :P/>
If you have original ecu contact Vauxhall and they will get the car pass for you with all codes needed for about £20-30
#295 smiley
Posted 24 February 2013 - 12:39 PM
If getting the code from vaux fails, send Peter your original ecu also. He can read the code from it.
#296 techieboy
Posted 25 February 2013 - 01:27 PM
I see from the manual that you can log readings from a wideband Lambda. How does that work? Can you just use an off the shelf OEM wideband lambda from a new'ish VAG car and log from that, or do you need to mess about with traditional widebands with a separate controller (and maybe a simulated narrow band output in place of the standard Z22SE Lambda). Wonder if it's possible to use a wideband permanently, in place of the pre-cat OEM sensor. :unsure:
#297 rik
rik
  • 2,187 posts
Posted 25 February 2013 - 01:41 PM
hehe I asked him exactly the same thing, here's what he said:
I also have a wideband lambda sensor, does it connect straight to the ecu via the egr
valve wiring or still go through my wb control box and then into the egr?
The wideband does not connect directly to the ECU and the software does not
use the input from the wideband to control the engine directly. The wideband
can be connected through the analog output of the wideband controller. For
this the output of the wideband controller is connected to the disabled EGR
input. The output is visible in the logged data, on the ignition and knock
measurement tab and in the power measurement graph. This way the output can
be used to manually correct the fuel table.
Edited by rik, 25 February 2013 - 01:42 PM.
#298 techieboy
Posted 25 February 2013 - 01:44 PM
:lol: thumbsup
#299 slindborg
Posted 25 February 2013 - 03:46 PM
imho there is a way to frig the lambda input to accept a wideband but its mega faff and wouldnt be 'that' accurate. But it would involve an external wideband kit that outputs a narrowband signal but with its switch over frigged to be at the point you want it. lots of frigging :lol:
#300 rik
rik
  • 2,187 posts
Posted 25 February 2013 - 04:03 PM
I dont mind having it run from regular narrow sensor - I was more thinking that I could skip a bunch of wiring if it accepted wideband natively, but then I thought about it more and my dash gauge would have nothing to connect to in that case, so it's probably just as well ........
