obdtuner remap z22se ecu
2116 replies to this topic
#321 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 March 2013 - 09:31 PM
Well done Rik, I look forward to hearing what you think
#322 oakmere
oakmere
  • 2,143 posts
Posted 11 March 2013 - 09:37 PM
I've put my order in guys, will let you know what it's like :)/>
Happy to help if I can.
Are you stage 2 SC or higher?
#323 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 09:47 PM
probably 2.5 i think, here's what the base map will be for:
- Engine type: Z22SE
- Cams with blower profile
- EATON M62
- Pulley size: 3,1"
- Injector Bosch 0 280 156 280 (Blue VXR injectors)
- Fuel pressure standard
- Fuel pump standard
- Pressure regulator connected to boost.
- 8.9 forged pistons
- 4-1 manifold
- 2.5" cat
- standard turbo silencer
- Dual pass modded lsj laminova cc.
- Radiator setup - it has 2 oil coolers at the front and 1 at the right hand side of the engine (with turbo ears) http://www.vx220.org...ooler-radiator/
- 2.5 Bar MAP sensor (Bosch 0 261 230 042)
- 68mm Throttle body (pins switched around in the connector)
#324 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 09:49 PM
nearly a year since I made that radiator post :o miss my car :(
#325 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 March 2013 - 10:48 PM
I'd defiantly get some kind of upgraded pump fitted before you map with this ecu. Mine fails to supply at high rpm on a CS map.
#326 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 10:56 PM
yeah will probably get the new pump before im done tank is full of year-old fuel - what do i do with it?
#327 Bargi
Bargi
  • 4,483 posts
Posted 11 March 2013 - 11:07 PM
- EATON M62
- Pulley size: 3,1"
- 4-1 manifold
- 2.5" cat
assume you've got some Eagle rods in there somewhere :)
#328 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 March 2013 - 11:08 PM
Drain it out or when putting the new pump in (you'll need to cut the opening bigger) pump it out. Go on eBay for the pump or speak to cliffie. Think I paid about £70 delivered. CS charge about £19 to fit if you have the cut put and seats/interior out the way. You then just need a flat metal plate (from dave H) to cover the opening. With your mods your good for stage 3 power. Wonder what this ecu can do for them kind of figures. Good luck
#329 smiley
Posted 11 March 2013 - 11:11 PM
Nothing more then CS can.
Just a cleaner fuel trim, better TB response and no hickups.
#330 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 11:12 PM
yep :)
#331 smiley
With the blue vxr injectors?
#332 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 11:13 PM
Good luck
i can pump it out, no problem
but then what do i do with 25L of old fuel?
Edited by rik, 11 March 2013 - 11:14 PM.
#333 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 11:16 PM
astra vxr (z20leh?) injectors they are
#334 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 March 2013 - 11:35 PM
No just tubby injectors for stage 2. On the RR at 5k rpm the fuel pressure dropped off and the ecu then dumps air in. This then explains the high temps and why my exhaust/ cat failed last year.
Edited by ArticMonkey, 11 March 2013 - 11:36 PM.
#335 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 March 2013 - 11:37 PM
Good luck
Accidently trip over on some waste ground or take it to a local garge or scrapyard to get rid/use in an old banger.
#336 rik
rik
  • 2,187 posts
Posted 11 March 2013 - 11:50 PM
would it work in my 1.2 corsa?
#337 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 12 March 2013 - 12:05 AM
Anyone got a email address i can email for this software please.
#338 smiley
Posted 12 March 2013 - 08:05 AM
halfway.
http://www.vx220.org...le/page__st__80
#339 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 12 March 2013 - 08:50 AM
It's fuel so yes but don't know if it will have any adverse effects.
Put it in the lawn mower or save it for a fire in the garden.
#340 smiley
Posted 12 March 2013 - 09:16 AM
Sound slike a choice of route to take.
Myself (and a few others) have had slightly lean at high rpm (6500 in my case) fixed by the blue injectors.
Good to hear that fuelpump replace can also fix it.
