#401
Posted 02 April 2013 - 04:06 PM
#402
Posted 02 April 2013 - 05:22 PM
As per the pm, chuck in more ign advance at idle, you can put lots in down there safely.
I have done this now. Back to closed loop with more advance I will see how it settles down. It already had more advance than standard but have added about 2.5 (not sure if the values are in degrees?) more this seems the best setting and I am getting better vacuum. If i keep adding advance idle starts to get worse until it becomes unstable.
Peter will be getting sport cams so I am sure he will be looking at this in more detail.
Hmm, annoying. Added some more fuel too? (Or backed it out)
#403
Posted 02 April 2013 - 06:01 PM
#404
Posted 02 April 2013 - 06:06 PM
#405
Posted 02 April 2013 - 06:22 PM
#406
Posted 02 April 2013 - 06:33 PM
#407
Posted 02 April 2013 - 06:36 PM
I'd look at fixing cold and hot start if the idle controller isn't right in closed loop. One thing that drives me up the wall is a crap idle, there is no excuse for it (not your fault in this case )I can't change fuel now as it is closed loop so if I add fuel the trim removes it?
All I can do is get the fuelling so the trims tend to zero. I have got a lot of extra advance in now! The advance is 5.4 as std I have now got it at 15.4 so that's 10 degrees. If I go to 20+ the engine starts trying to stall. The idle is so much better than on the std map just not perfect but I do have cams balance delete and lightweight fly all of which are destabilising the idle. In open loop the idle is back to OEM but it causes issues with cold and hot start which I can't seem to solve. So currently the choice is SLIGHTLY lumpy idle or the starting idle issues!
Thanks for your help as it has improved the idle further.
#408
Posted 02 April 2013 - 08:38 PM
N/A not SCare you SC or not? I have blower profile comp cams and idle is quite nice on default map with no changes
#409
Posted 02 April 2013 - 08:48 PM
#410
Posted 11 April 2013 - 04:21 PM
#411
Posted 15 April 2013 - 12:17 PM
#412
Posted 15 April 2013 - 01:51 PM
#413
Posted 15 April 2013 - 02:02 PM
#414
Posted 15 April 2013 - 02:32 PM
Cool! Just found this. Who using this on their NA? Is it safe? :P/>
Me
Safe as long as you don't put any silly ignition or fuel values in. All OE safety functions still active!
#415
Posted 15 April 2013 - 04:22 PM
Me
Does the software allow you to view Air Fuel Ratio values in real time?
#416
Posted 15 April 2013 - 04:35 PM
#417
Posted 15 April 2013 - 05:16 PM
#418
Posted 15 April 2013 - 09:06 PM
Only during logging irrc, and you may want to keep an eye on the road, instead of on the laptop.
Can't beat piloting a laptop while being driven about like a loon
Even more fun when the driver works out you can cope with the gentle assign about and then starts trying to make life hard by power sliding everywhere
#419
Posted 15 April 2013 - 09:17 PM
#420
Posted 15 April 2013 - 09:26 PM
Edited by smiley, 15 April 2013 - 09:27 PM.
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
